Low hot water temp.
campingcareys
Hello,I have the Atwood GE16 EXT hot water heater in my jayco,this spring the water coming out when try the hot water was very foamy,redrained/purged air out of tank/lines,turned on water heater,fires up,runs constantly ,it just gets Luke warm at faucets (90 degrees), 140 degrees coming out at bypass outside at tank.any ideas ?, I've never had an issue like this,I'm baffled,thanks
7 REPLIES 7
doxiemom11
Hubby didn't shut shower off at faucets, but just shut off the hand held shower head instead and I couldn't get hot water. Discovered that, shut off with the faucets and immediately had hot water. Check indoor shower too.
campingcareys
Thank you very much,I'll give this a try tomorrow hopefully,thank you
Old-Biscuit
janstey58 wrote:
This Atwood water heater has a "mixing valve" on the rear of the heater that may be plugged or inoperable. It allows the water heated to be hotter than normal, then the mix valve adds cold at a pre-set level to bring the water temp down to normal hot. You might check that.
Water Heater T-stat allows water to be heated to 160*F
Mixing valve has HOT IN and a COLD IN....set for 130*F out to hot water system
Hot In from tank to mixing valve gets clogged up and either get warm or cold water out of it (depends on how clogged hot in is)
Remove mixing valve and clean it out (CLR, Vinegar, Lime Away etc)
Rinse/flush out the HOT OUT on tank
Rinse/Flush Water Heater Tank thru drain
New OEM Mixing valves are expensive........other types can be used that are cheaper (still costly) from Home Depot, Lowes, ACE etc
campingcareys
Thanks for the replies. I did check the outside shower already. The bypass valve,how do I check that?, remove it ?, thank you
janstey58
Jeff and Kim
2015 Fleetwood Discovery 40E
Freightliner Chassis 380HP DP
2012 Ford Escape Limited Toad
Artum_Snowbird
You can also have a stuck open or partly closed check valve on the outlet.
If getting to the check valve is difficult and you want to check it, put the rig in bypass, drain out the HWT by removing the plug (be extremely careful if it's hot water in there.
Leave the plug out and run the pump. Water should not come out the plug now. If it does, you are letting it in backwards through a stuck open check valve. I spilled antifreeze all over the place when winterizing and I did not know my valve was stuck open.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
MFL
Nomad II
Nomad II
Sometimes the indoor, or outdoor shower is left on, but shut off at handle, which will allow cold water to mix with the hot.
Jerry
