Low-No propane flow question
Hemlockdj
Good day all,
So I have camped many times in winter in truck campers & trailers and never seen this issue.
Battery full charge(new)- Check
Propane tank full/on - Check
Heater No obstruction on vents/sail switch - Check
Hot water heater empty from winterization - Check
Went to load/prep our Class C 23C Chateau motorhome for a trip to San Diego last week. Nighttime temperatures here in Colorado low 20's, daytime 40-60. Friday afternoon, about 50 degrees, Turned on the Stovetop, gas flowing, good flame. Turn on frig on Propane, pilot light all good. Turned on heater, NO light!
Checked everything, seems fine.
Next Day, Saturday, went out to troubleshoot some more, outside temps about 35 degrees, stovetop NO flame, frig pilot working fine, heater still not lighting.
Drove south towards Santa Fe, NM on Saturday, outside temps around 60 degrees. Stop for the night, stove top, frig & heater all working fine on propane. Everything worked fine for the remainder of the trip.
For some reason propane was not getting to the heater & stovetop when it was cold outside. Never seen this. The heater and the frig are on the same side of coach and stovetop on the opposite side.
Any ideas?
Thanks in advance,
Dave
2017 23' Chateau
13 REPLIES 13
nineoaks2004
Turn LP off, then slowly turn it back on. If opened fast the safety assumes a bad leak and shuts the LP off. Open it slowly and you should get full propane to the appliances.
By the time you learn the rules of life
You're to old to play the game
Charlie_D_
My heater did the same thing. Igniter would spark, heater ran for a few seconds and shut down. Took it apart, cleaned stack and everything else. Problem continued. Opened heater a second time and there was a fine wisp of spider web that was difficult to see. Cleaned it out and everything works.
Enjoying Your Freedom?
Thank A Veteran
Native Texan
2013 Prime Time Crusader 330MKS
2018 Chevy 2500 D/A Z71 4x4 Offroad
2006 Holiday Rambler Savoy 33SKT-40,000 trouble free miles-retired
2006 Chevy 2500 D/A-retired
2013 Chevy 2500 D/A-retired
Esacnj
my problem was pigtail. replaced and solved problem. that was after trying regulator replacement. i should have tried pigtail first.
Esacnj
Hemlockdj
Thanks for all the replies, I will explore and see what comes of this. Happy camping.
Dave
2017 23' Chateau
enblethen
Yes, the regulator on the tank. Refers do not use much fuel so it is passing enough for it to operate.
Op has a MH that has one tank through a horizontal regulator.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
allen8106
Could be the pigtails from the regulator to the tanks. My Jayco 5th wheel was 2 years old and a similar thing happened to me. I replaced the pigtails and everything has worked fine since then. The pigtail have a high flow valve in them to automatically shut off if there is excess flow like in the event a line gets cut or broken. These high flow valves are prone to failure.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
Harvard
Most likely there is some oil pooling some where in your propane distribution. It becomes a problem when cold and viscous but OK when warm.
3_tons
If the heater lights but then goes out it could be the flame prover gone wrong - this happened to me on my Atwood so I removed it (near the exhaust port) and squeezed the two tuning fork like probes together a bit and everything has been fine for the last 5 yrs... I suppose that over time they get out of spec due to road vibration...
Hope this helps,
3 tons
Hemlockdj
Are you referring to the regulator on the propane tank? Why would the frig pilot work from the start and stovetop at first work fine, than stop? Not saying your incorrect, just trying to understand the process.
enblethen wrote:
Bad regulator that is allowing some fuel to flow through would allow fuel to accumulate in piping. It would allow for a major usage appliance to burn for a short time.
2017 23' Chateau
enblethen
Bud
USAF Retired
Pace Arrow
Hemlockdj
One thing I forgot to add, sorry, the heater would light for about 1-2 seconds than go out.
Hemlockdj wrote:
Good day all,
Any ideas?
Thanks in advance,
Dave
2017 23' Chateau
enblethen
My first thought would be failing regulator.
Bud
USAF Retired
Pace Arrow
2chiefsRus
maybe the tank was overfilled? That happened to us once. The liquid was freezing inside the regulator. We poured hot water on the regulator and were able to get the furnace to come on. After we used enough propane to bring it back to the appropriate level, everything worked fine again.
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2018 Ford F-150 & 2017 Harley Trike
Fulltime 2007 to 2016, now halftimers
Before you give someone a piece of your mind, make sure you can get by with what will be left.
Our Blog
National Parks Visited
