Magnadyne VCS-10 Video Switching Center
wd
Is anyone familiar with this unit? It doesn’t have a HDMI connector and I have 3 tv’s I am trying to connect through the center..I have tried composite cables from the 211z receiver going through the DVD connections and tried a rf modulator composite cables from the receiver to the modulator and having no luck. I am going from the modulator to a connection labeled “to satellite receiver output” on the panel. I can’t get the tv input to recognize the AV input. The instructions state to put the tv on channel 3or 4 but my tv doesn’t get a signal and automatically goes to the closest channel that is getting a signal.
I ran a HDMI cable across the room to the tv and it worked great. I know I can get a wireless HDMI component for the front tv but would like to connect the other tv”s to this station. I’ve had some help getting this far but I am stuck again. Any suggestions are appreciated.
1 REPLY 1
shastagary
have you done a channel scan or add a channel mode if your tv has it for ch 3 or 4 ?
the tv will not stop on a channel not in its memory from a channel scan.
the modulator must be on during the scan.
