Mean Well RSP-1500-15 Power Supply
mena661
I'll get to the point. Landyacht mentioned that this supply needs 17A. I don't see anything in a specs that mention this. Also, the specs say it's PF corrected. What am I missing? Thanks.
Specs
38 REPLIES 38
jrnymn7
mrgreetis wrote:
LY, google or even search on Amazon for "AC line splitter". It is a "figure eight" shaped gizmo that splits the 2 AC wires apart for current measuring.
splitter
I learned about it here an older post.
Mike
I just saw a video yesterday,on youtube, where the guy uses one of those... pretty cool.
mrgreetis
splitter
Mike
jrnymn7
mena661 wrote:
Ah I see. The high draw is at the lower voltages. No pot twiddling for me either! Well, that's out then. Back to the MegaWatt's.
Mena, How many amps do you require?
jrnymn7
LandYacht wrote:
"I wish it were easier for me to get my clamp on meter over a single ac line to check what it pulls when putting out 590 watts." (end)
...Get yourself a kill-a-watt. (it's not as deadly as it sounds)
mena661
landyacht318
mena661 wrote:
I think Randy's asking $275 for the Powermax 100A. There's no stages, you are the stages. ๐Ÿ™‚
ken white wrote:
Don't operate it at its maximum output current and it will work fine.
It may even work at or very near maximum output current since its specifications are so close to 15 amps...
That's true. I would only be using the low 15V range at most (it would be in the high 14's for charging) so I should be under it's max draw.
Unless you are going to be pot twiddling through out the whole bulk stage, this is not going to work. The meanwell advantage is it will do maximum output until battery voltage rises to near the voltage set by the pot. My 500 watt supply will do near 600 watts until battery voltage gets up near 14.7. You would have to keep the pot dial within a few tenths to keep it from maxing out on a large depleted bank. Too much work.. I wish it were easier for me to get my clamp on meter over a single ac line to check what it pulls when putting out 590 watts. See if it the same as the spec sheet.
mena661
BFL, it's time to add a couple of MW's to your herd. ๐Ÿ™‚ What's your credit card number?
BFL13
IMO there are two automatic stages once you set a voltage with the knob:
-Bulk while it ramps up the battery voltage to the voltage you set,
- Absorption where it does the absorption stage at the voltage you set, and then it stays there at that voltage forever as the Float unless you change that voltage
Other Stages are not automatic but are done by you with the knob:
Finish
Top
Equalize
Float
Stirring
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
mena661
BFL13
landyacht318 wrote:
09FLSTC wrote:
Install this weekend hopefully.
I want pics of the internals, and plotted charts on depleted batteries, or it didn't happen.
Kidding. What does the 100 amper with trim pot run for?
Prototype PowerMax variable 100 amper
Ignore damaged thermistor on left, now fixed. Red wires on right go to the four 40a reverse polarity fuses. External fan is on left--it blows air in. Vertical board lower middle with white wire on top--that wire is on the board where the little blue internal pot goes on the regular converters, but here there is no pot, but the white wire goes to the bottom (inside the lid) of the external knob on the lid that adjusts the voltage.
EDIT--so be careful if you take the lid off. The wires aren't very long and you do not want to yank the pot's wire off the top of that vertical circuit board (don't ask!) unless you like soldering while praying it will ever work again (mine still works ๐Ÿ™‚ )
Mena I don't know which ones Randy has on offer besides the three he shows, but the PM site shows a 120a one now as the biggie. Randy's site does not make clear if his version of the variable 75 is PF corrected like the regular converter 75s are.
Photo in Profile
ken_white
mena661 wrote:
Voltage is 120 at the power supply but the MH is plugged into a 15A circuit. So if I use ken's very handy calculations I'm looking at 15.12A from the Mean Well. Just a bit too much from that circuit.
2014 RAM C&C 3500, 4x4, Club Cab, Hauler Bed, DRW, Aisin, 3.73's, etc...
2013 DRV Tradition 360 RSS
LED Lighting
570W of ET Solar Panels
MorningStar MPPT 45
Wagan 1000W Elite Pro Inverter
Duracell EGC2 Batteries with 460 A-H Capacity
landyacht318
09FLSTC
landyacht318 wrote:
I'm not seeing the 100 amper adjustable on bestconverters site.
Do these have any automatic triggers for reverting to float, or are they full manual like the MW's?
Pretty sure they are full manual and you are the trigger. Better know your stuff. Install this weekend hopefully.
landyacht318
mena661
I'd like those Mean Well's but for the price of that 750W unit I can get the adjustable voltage, PF corrected Powermax 100A. The MegaWatt will indeed need the diode to run in parallel. The one you linked was the one I was going to buy. Shipping is only $5 to my house cause I live near the seller. I wish that 80A MegaWatt did more than 14.5V, I'd get that one. I did send the seller an email asking about specs. Will post his response.
