Mexicowander's new toy
NinerBikes
I'll have to let him explain what the heck it does, features, ratings, amps, Volts, etc. Probably BORG power supply related is my guess.
38 REPLIES 38
MEXICOWANDERER
****-A-Doodle-Doo
Chicken head knob image comin' atcha Niner around 1930 hours.
pianotuna
Nomad III
Nomad III
Oh the days of visiting the surplus bin. How I miss them.
Regards, Don
MEXICOWANDERER
It's phenolic black. And 2" from tip to base. A honker.
NinerBikes
Git 'er done, boy! You could have at least included the Rooster Beaker knob on top in the picture, slacker! ๐Ÿ˜‰
MEXICOWANDERER
Found this little Surplus puppy at Hal-Ted Electronics in the Silicon Valley. I got it because it is 20-amp Mil-Spec rated. 2-poles one for each Megawatt. Rotary of course. Snap Action which means when turning the chicken-head knob spring pressure builds until finally SNAP it clicks to the next position. Mil Spec rated for one million cycles. Ten dollars. Made in USA by Americans who will probably vote for Donald Trump. Actually it's new-old-stock meaning the people are probably passed away.
Getting all this unplanned stuff jammed into that SOLA case is becoming a task.
westend
Jack_Diane_Freedom wrote:
Powers the tin foil hat.
Negative on that.
It is a multiple pole switch that he uses to interrupt power to the local store, his daughter's house, and the nearby Pemex refinery. ๐Ÿ˜‰
'03 F-250 4x4 CC
Jack_Diane_Free
SCVJeff
A stackable wafer.. Wonder what that's from?
Jeff - WA6EQU
'06 Itasca Meridian 34H, CAT C7/350
JiminDenver
It's that switch Mr Wizard turned him on to.
2011 GulfStream Amerilite 25BH
2003 Ford Expedition with 435w tilting portable/ TS-MPPT-45
750w solar , TS-MPPT-60 on the trailer
675 Ah bank, Trip-lite 1250fc inverter
Sportsman 2200w inverter generator
