โFeb-19-2015 07:59 AM
โApr-30-2015 01:34 PM
โApr-30-2015 01:12 PM
โFeb-20-2015 09:22 PM
enblethen wrote:
I maybe reading this backward.
My rig uses four pole and the ground goes through the battery control circuitry to delay closing the relay until primary battery had reached a specified level.
If he is replacing a three pole with a four pole then yes, he just needs to provide a good solid ground to the bracket.
If the bad replay is a four pole and the replacement is a three pole, then it will not work.
โFeb-20-2015 07:09 PM
Bud
USAF Retired
Pace Arrow
โFeb-20-2015 06:16 PM
enblethen wrote:
I just re-read it. Still need to know what kind of circuit OP has as to whether the ground goes through a network to operate. I three posted unit will not work in a four post system.
โFeb-20-2015 02:58 PM
Bud
USAF Retired
Pace Arrow
โFeb-20-2015 10:29 AM
enblethen wrote:Did you not read my first reply?
If there is only one small terminal, it is the power connection. The ground would be through the metal base.
Some rigs route the ground through a monitoring system.
Verify that the old and new relays are exactly the same configuration.
โFeb-20-2015 07:10 AM
Bud
USAF Retired
Pace Arrow
โFeb-20-2015 06:20 AM
BJean wrote:
OnaQuest: I have 2 ground wires runing to the single ground on the bad unit. I do not know how to figure out which one should go to witch of the 2 ground posts on new unit. Any help would be of great help.
I appreciate al of the help that I have gotten.
โFeb-20-2015 05:59 AM
โFeb-19-2015 02:05 PM
โFeb-19-2015 12:45 PM
Bud
USAF Retired
Pace Arrow
โFeb-19-2015 12:37 PM
โFeb-19-2015 11:10 AM
