Monitor Panel mod
Kennyg
I have a panel in which ONE bubble switch is defective. They do not sell individual switches. It costs $145 to replace the whole panel.
The panel p/n is MON PNL- 12V 3WAY PMP SWT W/GEC07-0303.
Question- Can I take wire which monitors the gray tank level which isn,t working with the fresh water bubble switch??
https://rvparts.argrv.com/e2wItemMain.aspx?parentId=1303853&parentLink=2100000100:3100002490:3100002...
All help will be appreciated.
Kennyg
2 REPLIES 2
Kennyg
DrewE wrote:
You should be able to swap the wires to the two tanks, at least assuming this uses anything like a halfway typical tank monitor circuit.
I would also guess that a little cleverness and work with a drill press might allow one to replace all the bubble switches with normal pushbutton switches, and probably with a little care it could be done fairly neatly.
Thanks for the advise. Will try the wire swap. Thanks for input.
Kennyg
DrewE
