โMay-08-2014 10:33 AM
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
โMay-10-2014 08:34 AM
Toad: 91 Zuke
โMay-09-2014 09:28 AM
โMay-09-2014 08:47 AM
MEXICOWANDERER wrote:
Beware of hype. Most retailers are more bogus than a three dollar bill when it comes to honesty or even intelligence about their LED product.
MEXICOWANDERER wrote:This could be a very long discussion. In my opinion, it depends on one's idea of efficiency. For the RV not connected to shore power, there are several considerations in determining LED efficiency.
I have come to the conclusion after purchasing CREE, SMD, Bridgelux, and every other damned type of LED lamp that watt for watt they offer ZERO percent advantage over G.E. CFL lamp lighting efficiency.
Toad: 91 Zuke
โMay-09-2014 05:50 AM
โMay-08-2014 07:23 PM
OPINION TIME
Remove lens. Measure the space available INSIDE the fixture. Height by width.
Find the combination of SMD's on plates (the plates vary by the number of smd's mounted in them). The combination. Whatever sizes it takes to CRAM the maximum number of LED's into the space. Take the stupid bulb mount out to get more space, if you need to.
Found out by trial and error that pasting the plates directly to the lens rather than to the base yields A LOT MORE LIGHTING. So you got dozens of bright points shining through the lens.....sue me. It's worth it.
The micro wiring that comes with these plates is hard to work with. You need to SOLDER the wires to a common junction. Easily done on a kitchen table because you are working with the LENS and not the base. 18 gauge makes a fine connection to the whatever color positive and negative wires that feed your fixture.
But don't overlook pasting the plates to the LENS. For me, it yielded at least TWICE the light. Those plastic lenses are garbage. The right way to go would be leaded crystal glass. But if you paste the plates to the base you might as well stay with incandescent IMHO.
โMay-08-2014 04:07 PM
mchero wrote:10 pages of LED in heading
where do I go to figure out what bulbs I need.
โMay-08-2014 01:20 PM
โMay-08-2014 01:08 PM
โMay-08-2014 12:51 PM
โMay-08-2014 11:44 AM
