More Solar for "Us"
MrWizard
Moderator
Moderator
Ok, I went off.the deep end?
Bought 3 used 37watt uni-solar panels and a blue sky 2000e controller for the hefty price of $400,
They were being listed as 75w panels, they are not
The tested open circuit voltage was 21+, short circuit amps 2.9
I tested each panel multiple times tilted into the sun and laying flat on the ground , got the same readings each way, that was the deciding factor, they appear to put out full power while laying flat, I will try to mount them tomorrow before it gets hot, right now 104°F
I will use the existing wiring until I buy & install the new wire
I can explain it to you.
1997 F53 Bounder 36s
715 REPLIES 715
grizzzman
MrWizard wrote:
New Solar controller, Grape Solar 40a PWM, with Blue tooth remote monitor and setup, using my Android tablet
Would you mind grabbing a screen grab settings set to lithium?
Thanks
2019 Ford F150 EcoBoost SuperCrew
2016 Rockwood Mini Lite 2504S. TM2030 SC2030
640 Watts Solar. Costco CG2 208 AH and Lifepo4 3P4S 150 AH Hybrid. ElectroDacus. Renolagy DC to DC charger. 2000 Watt Inverter.
Boondocking is my Deal
MrWizard
Moderator
Moderator
Pictures were taken right after I started tweaking the settings
Battery type is now SLD sealed aka AGM
It also has a setting for lithium batteries
I posted the pictures so you'all could see all the settings that could be changed
It also has a data saved page aka 'record'
Which keeps daily records
But it seems flaky, some days are missing, showing blank data fields and incorrect math 17Ah total 1.88kWh
I sent them an email about that, got an answer they would forward to engineering
But so far I'm real happy about being about to set my own charge profile
BFL13
FLD? ISTR AGMs?
Looks like a very good controller and a 40 amper at that!
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
MrWizard
Moderator
Moderator
MrWizard
Moderator
Moderator
Wed June 8 2016
23.05 peak amps
325.6 peak watts
148.00 ampHrs
2043.5 watt Hrs
MrWizard
Moderator
Moderator
the panels are flat
and thanks to my new Amp/power meter on the kitchen wall
i can see that the batteries are getting a few amps at 7am, and still getting and amp at 7pm when i take the daily reading
and 'reset' the solar watt meter counter
bigfootford
Nomad II
Nomad II
MrWizard wrote:
Wed 4-27-16
25.56 peak amps
362.9 peak watts
164.09 amphrs
2328.8 watt hrs
similar results on Monday and tues
two day total for Mon & Tues
307.1 ampHrs
4244.2 watt hrs
need some rain to wash the panels
164 ah is great... At 25 panel amps max that would be over 6 hrs st 25 amps.... We know that 25 is peak. Sun up time is, what, about 8am to 6pm? So 10 hrs to get 164ah... That is an average of 10ah per hr... damnnn goooooood! And you do not tilt your panels do you?
Jim
2000 2500 9.6 Bigfoot,94 F250, Vision 19.5, Bilstein shocks, air bags/pump, EU2000, PD 9260, Two Redodo 100ah Mini's, Aims 2500 Conv/Inv, 200W. solar, Morningstar Sunsaver 15A/ display panel, Delorme/laptop for travel, Wave-3 heat.
MrWizard
Moderator
Moderator
Wed 4-27-16
25.56 peak amps
362.9 peak watts
164.09 amphrs
2328.8 watt hrs
307.1 ampHrs
4244.2 watt hrs
MrWizard
Moderator
Moderator
that rain wash Weds & thurs morning really cleaned the panels
Friday 2-19-16
1828.1 whrs
136.7 Ahrs
Sat 2-20-16
1993.0 whrs
147 .07 Ahrs
new records for this time of year
MrWizard
Moderator
Moderator
Fri Jan 22, 2016 quartzsite
23.44 peak amps 323.0 peak watts
1472.2 watt hrs 107.95 amp hrs
MrWizard
Moderator
Moderator
Wed jan 6, 2015
heavy rain, but the Sun came out around 1:30 PM
334.7 wh
25.82 Ahr
352.0 PW
25.92 PA
clean panels, cool air, high sun, low batteries
this situation doesn't happen every often
i did not run the generator in the rain , so the batteries, really needed that solar charging
as you can see the total for the day was less than the peak amount
that good sun did not last long
most of the days total was collected in just over one hour
MrWizard
Moderator
Moderator
Thurs Dec 24
17.95 PA
253.2 PW
1113.0 WHr
82.58 Ahr
a little cool air and Sunny skies is good for solar output
MrWizard
Moderator
Moderator
today Dec 23-2015 sunny with a few clouds
19.25 peak amps
268.0 peak watts
70.16 amp hrs
965.8 w Hrs
watt ? a difference
pianotuna
Nomad II
Nomad II
On the one hand--50 nights a year--no need for a generator even with a modest solar system, so long as there is a large battery bank.
On the other hand--full time--unless there is free shore power available, or a massive solar system with HUGE battery bank, a small generator for battery charging is worthwhile.
Mr Wizard is somewhere in between.
I know that in late October I use 20 kwh per day which would be hard to do with solar alone. But I also know that generator power works out to about $0.40 per kwh. So I need a 15 amp shore power connection.
I can manage pretty well for May and June, but July and August I need to run the air conditioner, consuming 30 kwh plus per day. September and early October works well.
I'm hoping that once I acquire one of those Mexican Autoformers that life will be much easier. I'll be able to use load support and dial down to 13 amps of input allowing for 2 amps for preventing voltage sagging.
Regards, Don
JiminDenver
Using a single panel on the truck to keep the bank happy over the winter has taught me a lot about the effect of the low winter sun on output and why people tilt. With the weather we have had recently, I sure wouldn't want to be out there without a generator.
2011 GulfStream Amerilite 25BH
2003 Ford Expedition with 435w tilting portable/ TS-MPPT-45
750w solar , TS-MPPT-60 on the trailer
675 Ah bank, Trip-lite 1250fc inverter
Sportsman 2200w inverter generator
