โAug-19-2013 02:21 PM
โAug-23-2013 05:19 AM
โAug-22-2013 07:46 PM
Salvo wrote:
We're in boost for just a short time. It doesn't matter if controller is a couple of minutes longer in that mode.
โAug-22-2013 07:41 PM
โAug-22-2013 06:30 PM
โAug-22-2013 11:45 AM
โAug-22-2013 09:24 AM
Salvo wrote:
How are you getting your measurements? Do you rely on the charge controller for current and voltage measurements? That is not very accurate. Someone posted Rogue controller data and it shows more power going out than coming in. In other words, the controller is more than 100% efficient! There are significant measurements errors in this controller. Sal
โAug-22-2013 08:54 AM
โAug-21-2013 04:18 PM
โAug-21-2013 07:49 AM
โAug-21-2013 07:48 AM
KJINTF wrote:First, thanks for posting your data! I will try to budget some time for collecting and graphing with MS View and get some numbers up in this thread.
O&S
Not asking you to spend more $$ - glad to hear your system works for you
Just asking for some real world efficiency numbers from other controllers
I have to assume like you most folks simply do not care what the efficiency numbers are if the battery gets charged all is good.
Was hoping/expecting there were other techs here at RV.NET that would take a few minutes to collect some data. I expect at least a few others have the needed equipment to take the measurements, collect the data and put it into a simple .csv file then produce a simple graph.
Then again maybe not
โAug-21-2013 07:37 AM
KJINTF wrote:
O
โAug-21-2013 06:19 AM
โAug-21-2013 06:09 AM
โAug-21-2013 05:23 AM
