Need parts for a 2013 Coachmen Mirada
RCabanas
I need to replace the electric compartment door on my 2013 Coachmen Mirada (I'm the guy who closed the rear slide with the electric compartment door open yesterday.) The door frame was demolished as was the hinge. The door itself is somehow OK and looks like it could be used.
Preliminary information I have obtained from a dealer is that the door, hinge and frame are are purchased as a one piece item. The door comes unpainted so it needs to be painted. (Luckily for me, there are no decals in this area of my RV.)
Seems to me if I can get the part from the dealer as he describes - in one piece - then installation should be pretty simple......just screw the frame in. I am hoping the door could be ordered pre-painted from the factory or at least that the dealer could paint it at his shop before I pick it up.
Has anyone had similar experiences, and how did you go about completing the repairs? Feedback appreciated.
Bob Cabanas
3 REPLIES 3
enblethen
Try Colaw
Measure your compartment before calling. I was able to get replacement from them that was even the same color.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
GDS-3950BH
You should be able to find the door easily. The install is easy. Forget Coachmen painting it if you buy it through them, most likely an exercise in frustration.
I would not put much faith in having an RV dealer paint it either. They would probably have some prior french fry technician spray it with a rattle can lol. Not many RV dealers that I know of do paint, other that spraying some black Krylon on over the rust of a rusty A frame with no prep.
Get the door and take it to a local body shop, take your checkbook. The paint will probably be more than the cost of the door.
midnightsadie
if you find the part? your real lucky. things change over night.
