RV damage and repair fix help
RVBD123
Hey how is everyone? I recently bought a 2021 Coachmen Leprechaun Model 260DS. Past week there was an issue caused by negligence and I caused some damage. Curious if anyone has any advice on how I could possibly repair some of the parts, or if I would just be better of replacing/going to a body shop.
I appreciate any help or advice moving forward.
16 REPLIES 16
RVBD123
Last question is regarding my difficulty finding the replacement panel for the propane tank area. Anyone have any recommendations on a website? I've contacted the dealer it seems like it would be a 2-4 week wait for a unpainted piece.
Body shops have told me they would not be able to work on the panel has it is aluminum and the center piece is hallow. With that said at this point I'm leaning more toward just replacing the part, in the mean time I have nothing to lose by trying to straighten it using a wood block and rubber hammer.
IAMICHABOD
RVBD123 wrote:
Might be a silly question, but when it comes to measuring for the right size, is there a specific way to measure? Is it from the inside of the opening or outside?
Not silly at all,if you are replacing the lid that you had in the picture. No need to measure at all.The opening on them are all the same and the replacement lid will fit. The only thing to worry about is to get the right hinge type by using the picture on the list posted.
2006 TIOGA 26Q CHEVY 6.0 WORKHORSE VORTEC
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
RVBD123
IAMICHABOD wrote:
All good information so far I think,as for the vent cover that is an easy one.
First see what type vent lid you have using this
For long lasting vent covers Polycarbonate ones are the ones you want.
If you haven't done this before Here is a short video that will help you.
You may need a new seal that goes on the metal edge this will make it a tight seal This is what you need
Replace like this
Maxx Air covers are also a good Idea,mine have been on for 9 years and look good as new.
midnightsadie
private body shop never the dealer, most likely the dealer will sub it out.
Tom_M1
The OP did not say neighbor. He said negligence.
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
wa8yxm
You said the issue was caused by a neighbor. I Gather said neighbor hit you while you were parked. In most states this costs you NOTHING if you go to a Body Shop as said neighbor has to pay for the repairs (Same as if he hit your house) so I'd say get it done professionally.
RVBD123
Thank you for all the information and help provided so far. Greatly appreciated.
Beverley_Ken
As BFL13 Says the vent cover is easy. I can't tell from the picture, but the lever that raises it may just have popped out of the track attached to the actual plastic cover.
The compartment door. Remove the two screws in the ends of the hinge and slide the door off. Try to flatten it out, use a block of wood to smooth out the edge trim, touch up paint if needed. If you are not comfortable doing this take the door only to your local body shop.
Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
IAMICHABOD
Replace like this
BFL13
The roof vent cover is easy, just buy the parts (there are different models of those, so get the right one.)--before it rains!
The bent door can be bent back so it closes again. Might leave a wrinkle or two, but who cares? If you have insurance for that, use it. Then get the whole thing done, frame and all.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
RVBD123
RVBD123
BFL13
https://coachmenrv.com/class-c-motorhomes/leprechaun/260DS/1527
What damage? One thing is if you hand it in for them to fix it, you will not have the Rv for a long time, so no camping. If you can fix it yourself and keep camping with it as required, that can be good.
It is mostly about money and insurance though.
also this time of year until it warms up next year it will be too cold out to use some of the glues/tapes/paint you might need. "They " have heated indoor shops.
Photo in Profile
RVBD123
Damage is to the dome on the top of the roof and the door for the side pod is bent. I was attempting to post photos but I am having difficulties posting them here.
Damage is strictly just bent pod covers and dome lid on the roof.
