New smart TV
tedp
I've installed a new Samsung smart TV in my motor home and I cannot get it to see the cable channels. I know the cable works because I can get my old "dumb" TV in the bedroom to see all the cable channels. I know the coax between the switch box and the smart TV is good as I can get over the air channels using the antenna. Could my switching box be bad? Any other help would be appreciated.
17 REPLIES 17
tedp
Got it! The switching hub cannot be powered on when using cable.
Thanks for all the help!
jdc1
tedp wrote:
jdc1 wrote:
If you are using a "smart tv", why are you not streaming it via your wifi?
Not good enough wifi strength
I can stream off my phone. At home I can stream off my Netgear wifi module a 100+ feet away.
tedp
way2roll wrote:
tedp wrote:
Retired JSO wrote:
Run a length of coax from the working bedroom TV to isolate where your problem is, wiring or TV.
Ran coax from the campground cable direct to the back of the smart TV and it worked. So it means it's in my switch box I guess. Right?
Maybe. If running it direct from the pedestal worked, why do you need the switchbox at all? But if you want to keep the switchbox do you have the input and output the same? Maybe your switchbox isn't compatible or it's malfunctioning.
I thought maybe it was the switch box as well. It works for over the air channels so I switched around the leads from the antenna in and the cable coax in and that didn't work either.
I assumed I'd have to have the switch box so the bedroom TV would have cable as well.
tedp
IAMICHABOD wrote:
I found on my Smart TV that the power supply had to be off when hooked to campground cable for it to work.
That didn't work, thanks!
lap527
same here...
2006 Dodge 3500 dually 4X4 / 2013 Livin Lite 10.0 TC /Torklift talons, fastguns, stableloads, superhitch, and truss/ towing a
14'V Nose Trailer when needed.
way2roll
Navigator
Navigator
Jeff - 2023 FR Sunseeker 2400B MBS
IAMICHABOD
2006 TIOGA 26Q CHEVY 6.0 WORKHORSE VORTEC
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
enblethen
What inputs are shown on the setup screen?
What method are you trying to connect through? Actual cable from a provider?
Try switching TVs at the video box.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
tedp
way2roll wrote:
Have you changed the input on the TV to the COAX input and scanned the channels?
No coax in the input screen.
tedp
enblethen wrote:
Verify the TV is set to cable and not antenna.
It is
tedp
tedp
jdc1
Lwiddis
Retiredโ€™s suggestion is great.
