No gas flow to oven
philh
Stove works fine, in two years we've never used the oven, and the one time we attempt to use it, it doesn't work.
Suggestions? Not smelling propane when it's on.
7 REPLIES 7
philh
beemerphile1 wrote:
Did you push/hold the button? Did you light the pilot?
That was it, thank you!
philh
That was in fact it. Beautiful flame now, thank you
philh
DOH, maybe I should read the instructions! Never considered holding in the knob.
wnjj
This. There will not be gas flowing to smell unless you hold the knob in to supply gas to the pilot flame. Once lit, the heat from the pilot will allow the main gas to flow when you turn the oven on.
If you want to cheat a bit, hold the lighter where the pilot flame goes, wait for a bit then turn the oven directly on from there.
Old-Biscuit
If you have gas flow to stove top burners you have it available for oven
As asked...does the pilot flame light off/stay lit?
Brand/Model would be helpful
robatthelake
Have you checked under the cook top for a shut off valve to the oven?
Rob & Jean
98 Dutch Star Diesel Pusher ..07 Honda CRV AWD
beemerphile1
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
