โMar-15-2022 04:38 PM
โApr-01-2022 11:18 PM
โMar-31-2022 10:13 PM
JBarca wrote:HTElectrical wrote:
I would not use CLR.to Caustic.
There is a product called RYDLYME Biodegradable Descaler Great stuff. I service Steam generators, and Boilers, and this is the industry preference.
Hi HTE,
The Rydlyme looks to be some good stuff, wish I knew about it for work as we had to clean out steam and water cooking tanks. I did not see it rated on aluminum. I may have missed it, have you used it on 7072 aluminum which is what the Atwood water heater tanks are made from?
Just checking.
Thanks
John
โMar-31-2022 10:11 PM
โMar-31-2022 12:02 PM
โMar-30-2022 08:03 PM
โMar-30-2022 06:09 PM
โMar-30-2022 05:18 PM
MrWizard wrote:
Yes there was some calcium deposit, I cleaned out of the elbow, there could be some in the WH but all I ever get when flushing or draining is clear water, any deposits are harden and pre-existing from the previous owner, I was surprised when I saw the deposits in the elbow and check valve,
I thought about removing the pop off valve and pouring a few gallons of CLR into the water heater via a funnel and letting it soak overnight, put it on bypass leave it turned off,
Then drain & flush the next day
Any body try this,
I've been looking at Cellphone Borescopes online , it's been several times now that I could have used one to inspect a problem situation
โMar-29-2022 04:40 PM
Bud
USAF Retired
Pace Arrow
โMar-29-2022 03:50 PM
โMar-29-2022 03:27 PM
โMar-28-2022 10:03 PM
โMar-28-2022 02:20 PM
Bud
USAF Retired
Pace Arrow
โMar-28-2022 12:42 PM
โMar-28-2022 12:29 PM
