Norcold N811 fridge-no power
agesilaus
OK we have a Norcold N811 and it was working fine a few weeks ago. We powered it fdown when we got home. When I tried to power it up again to get ready for another trip the display is blank and it does not respond to the on/off switch.
1) 12V Fuse is OK
2) Checked 120V outlet that the fridge is plugged into with an outlet tester and it is fine.
3) Propane is OK, runs stove burners and oven OK
so this seems to come down to the circuit/power board.
I don't know where the power board is tho, is it inside this black box in the outside access hatch?
Also how can you get to the on/off switch, there doesn't seem to be any way to open the panel. Do you have to pull the fridge out from the wall?
Thanks for any help or suggestions.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
15 REPLIES 15
Old-Biscuit
Have to have 12VDC TO the fridge before ANYTHING will work
No DC...NOTHING works (Display, control panel, interior light, AC Element etc)
That Black box ....cover for circuit board
On the Circuit board at couple of fuses
Glass 5A for the AC Element
Auto Blade 5a for ALL DC
Also the RV Main DC Fuse goes to 12VDC+ Terminal on circuit board (Yellow wire?) and GND1 Terminal (Neg) S/B White wire
See Pg 11 for DC information
See Pg 45/46 about removing cover on lower circuit board AND the display control panel
N6XX/N8XX Service Manual
Picture of a Norcold N6XX/N8XX circuit board
