Nuwave induction cooker
pianotuna
Nomad III
Nomad III
Hi all,
I tested my nuwave on a 1000 watt pure sine wave inverter. I could use the 375 F setting. 425 F caused the inverter to overload.
Regards, Don
11 REPLIES 11
pianotuna
Nomad III
Nomad III
Hi,
A real life test. I was just about to make croutons when the power went out. For fun I chose to do them using the inverter. It worked like a charm.
Regards, Don
MrWizard
Moderator
Moderator
Johno02 wrote:
If you are going to add a new sircuit for an RV hookup, go ahead and make at lease a 30A circuit.
Houston Remodeler wrote:
I am seriously thinking about adding a new, 20amp, home run outlet outside the TT for using both at the same time.
he is talking about a New outlet in the TT wiring from the breaker panel to the outside of the tt, to cook with the induction cooker outside
(a 'home run' is from the circuit breaker panel, a new circuit..its electrician speak)
I can explain it to you.
1997 F53 Bounder 36s
Johno02
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
TexasShadow
I like mine for frying stuff outside.
TexasShadow
Holiday Rambler Endeavor LE/ 3126B Cat
Sometimes BMW K75 on Rear Carrier
Jeep Grand Cherokee or 2016 Ford XLT 4x4 super cab with 8 ft bed
M&G aux brake system
854 Watts of Solar Power
Always remember you're unique, just like everyone else.
Houston_Remodel
We have 2 Nuwave cooktops. The big advantage is the ability to set the watts to 1500, 1000, or 600 as not to blow a fuse.
2015 Starcraft Launch 24RLS
2014 Ram 2500 diesel 4x4
Guarded by 2 Jack Russells
Johno02
We love our induction cook top.
gbopp
rjsurfer wrote:
Why the interest in Induction cook tops? Propane cooking is very efficient and there is a reason why ALL professional stoves are gas driven.
Ron W
It's nice to have options. And, I believe some of the new motor homes are all electric.
Apparently some just don't like propane.
brulaz
Another Con would be the noise. Our Duxtop induction cooktop can also run with our 1000W inverter at heat level 3 (700W) and below. But it runs a fan all the time to keep the internals cool.
Another con specific to the Duxtop, is that the plastic control surface is flush with the glass top. If you pull a hot pot onto the plastic it will melt, although there is a protective cover. But ours is still operational despite being scarred.
We also have a 900W full immersion 1L electric water kettle. It's quieter than the Duxtop when just heating water. Both are very efficient electrical heaters for use when boondocking.
Like others, we use ours more when it's hot, and when boondocking and there's lots of solar.
2014 ORV Timber Ridge 240RKS,8500#,1250# tongue,44K miles
690W Rooftop + 340W Portable Solar,4 GC2s,215Ah@24V
2016 Ram 2500 4x4 RgCab CTD,2507# payload,10.8 mpgUS tow
edatlanta
Ron W
Pros:
Less heat inside RV
Faster than propane
Instant heat and temp change
Constant even heat
Cons:
Requires a pretty good electrical load, but only when actually running and the heat setting.
I have one and I have never used my propane stove since I got it.
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
rjsurfer
Ron W
03 Dodge 2500 SRW,SB,EC
2018 Keystone 25RES
DRZ-400SM
DL-650
westend
Thanks Don. I may get one of these.
'03 F-250 4x4 CC
