โJun-11-2019 09:16 PM
โJun-14-2019 08:23 PM
โJun-14-2019 06:45 PM
โJun-14-2019 09:48 AM
โJun-14-2019 12:02 AM
โJun-13-2019 08:22 PM
โJun-13-2019 06:32 PM
S Davis wrote:
I think at this point I will go with two 8Ds, that way I can achieve the magic 20% charging with the Outbacks 125amp charger. The Outback inverters can be stacked so in the future if I need more power I will add another inverter and two more 8Ds.
โJun-13-2019 06:24 PM
โJun-13-2019 05:36 PM
โJun-13-2019 05:11 PM
โJun-13-2019 03:58 PM
S Davis wrote:
If I split it into four batteries it would be an additional $250.00 to $300.00 not to mention the cost of the extra wire and connectors to get 500ah. Is it worth the extra cost?
โJun-13-2019 03:49 PM
MEXICOWANDERER wrote:
You nailed it ๐
8-D batteries are indeed pickier than other jars. Tall jars are the least picky. Picky means per amp hour their CCA may be more but time to recharge may be a bit longer .It isn't enough to dissuade choice of BCI models.
Here is an AGM tip. If you can source a precision ammeter, float maintenance whole and fractions of an amp readings can offer valuable clues as to the condition of the battery. But measurements must be taken at the same ambient temperature. Same for a 12.234 digital voltmeter.
โJun-13-2019 03:09 PM
โJun-13-2019 02:57 PM
โJun-13-2019 01:52 PM
