Onan 5500 won't stay running on the road
stro1965
My Onan 5500 (1 year old rig, very few hours on the generator) will start and run just fine at a standstill, but it dies while I'm driving down the road. I think it's running, only to find out that it died at some point. Any ideas? It's still under warranty but trying to get it into the dealership in the near future is impossible.
2018 Ram DRW 3500 6.7
2019 Keystone Alpine 3021
8 REPLIES 8
Big_Katuna
Mine started shutting off when I hit a bump or made right hand turns.
I assumed it was the float so was going to take the carb off and clean/inspect it.
When I went to remove the carb one of the nuts was loose on the stud and the carb was bouncing around on the studs.
My Kharma ran over my Dogma.
Big_Katuna
Sam_Spade
westend wrote:
Checked your oil level?
Two small clarifications:
The low oil sensor can trigger going down the road even if the oil is not really low standing still.
AND
Most Cummins Diesel dealers also service Onan generators. They should be fairly easy to find near Interstates.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
dougrainer
stro1965 wrote:
I have not. Will do.
MOST common problem when a genset stops in transit but runs fine parked. Low oil causes the oil pressure switch to activate due to the low oil level. When you stop or turn the low oil moves to one side of the crankcase and causes the Pressure Switch to momentarily lose oil pressure. Doug
stro1965
Son of Norway wrote:
What kind of load do you have on it while you are driving down the road?
Miles
Just the front A/C.
Son_of_Norway
Miles
Miles and Darcey
1989 Holiday Rambler Crown Imperial
Denver, CO
stro1965
westend
'03 F-250 4x4 CC
