Onan’s plastic starter motor gear breaks easily Alternative?
rajdude
Hello everyone,
I am really tired of my Genset’s starter motor gear breaking or stripping.
This has happened twice in the past two years. Every time it happens, I replace the gear and the bendix drive…only to break again after some time. it is a royal pain to replace it. I have to drop the whole genset out of the Motorhome.
I see many other threads on the internet about people having the same problem. People say Onan makes it out of plastic to prevent damaging the flywheel. I say that is BS. All other starters I have seen have metal gears, nothing damages that heavy flywheel.
I have tried calling people who make aftermarket starters, hoping someone makes a different design…. Hopefully something with a metal gear but have not found any luck, yet.
Any alternative / solution?
Tips on getting the starter last longer?
By the way, Onan makes a Starter drive kit (p/n 191-2313, 191-2157). I can find it online for around 25 bucks. I can also find a aftermarket starter for $35. Last two times, I have replaced the drive kit only. This time I am thinking about trying to replace the whole starter.
My Genny’s Technical details:
Onan Model 4KY (Spec K)
4000 watts
Onan Starter. p/n 191-2351 (we have older p/n 192-2312)
Drive Gear: 24 teeth
-Raj
rajdude.com
'02 Fleetwood Terra 26Y MH
5 REPLIES 5
rajdude
I have not tried to check that. I have ordered a new starter motor for it. Once I drop the genny, I will check the flywheel.
Not sure if that is the problem though.....because when the genset runs, it runs absolutely fine....runs fine on load as well.
Kpackpackkelley wrote:
How hard is the flywheel to turn by hand ? If its to hard to turn the valves may need set to spec.
-Raj
rajdude.com
rajdude
No I am not doing that. I always let the genny stop rotating before re-trying to start it.
Generator Jim wrote:
Could it be that you are reengaging the starter before the engine comes to a complete halt. ONAN specifically mentions that in their manual/s
JimL
-Raj
rajdude.com
Kpackpackkelley
Generator_Jim
JimL
Jim & Jane Latour
08 Chevy 3500HD, crew cab, dually, Duramax/Allison
Crossroads Cruiser CR305SK14, Onan 3.6KY
Retired AF CMS (E9) Power Generation and Onan RV genset Level III tech
Grand Strand Sams
Blog.rv.net
MEXICOWANDERER
For truly expert opinion about this call ROMAINE ELECTRIC...
8811 S 208th St Kent, WA 98031
(425) 264-1700
