onan spark arrester
badboy368
Has anyone had any experience on cleaning/servicing the spark arrester on an ONAN QD8000 generator? I know it needs done, but i just cant seem to find the location of the brass plug that needs to be removed and the procedure to clean it out. Any help would be greatly appreciated.
40' pusher,350 turbo cat, pullin a 37' trailer haulin a drag car. oh yea baby
3 REPLIES 3
1492
Moderator
Moderator
Moved from Forum Technical Support
badboy368
WOW...got it. Thank-you for the help. Really was an easy task once i found out what to do. I was a little concerned because my onan has 947hrs. on it and it has never been done. Once i took the plug out, i saw it had very little soot on it.
Valkyriebush
I cleaned it on my onan 7.5. I needed a long extention and socket to remove and get to it. Wasn't much soot in it. Not difficult on mine, but I had to get a flashlight and look higher up to find it. the 8 might be similar.
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
