Jan-07-2014 04:41 PM
Jan-09-2014 05:48 AM
Rmack1 wrote:
This 'emergency power supply' thing has jumper cables, but they are suppose to be used for charging up batteries. Will it work backwards?
Jan-08-2014 05:39 PM
Jan-08-2014 05:36 PM
Jan-08-2014 05:32 PM
pianotuna wrote:
Hi,
You do have to disconnect the converter. Some folks prefer to automate that with a transfer switch--but I simply unplug mine.
Jan-08-2014 05:26 PM
pianotuna wrote:
Hi,
If it has "jumper cables" just fasten them onto the battery bank. See above for the most ideal way.Rmack1 wrote:
I suspect there is no easy way to use this inverter for my trailers needs, so I won't even ask.
Jan-08-2014 10:59 AM
Jan-08-2014 08:15 AM
Jan-08-2014 04:34 AM
Rmack1 wrote:pianotuna wrote:
Hi,
Interesting. I can almost see this snake eating its tail with my aux power supply hooked up to my hitch batteries with my shore power cable plugged in......almost.....I'm trying.
Jan-07-2014 09:33 PM
Jan-07-2014 08:10 PM
pianotuna wrote:
Hi,
Jan-07-2014 08:01 PM
Jan-07-2014 07:57 PM
Jan-07-2014 07:48 PM
BFL13 wrote:
Can you just clamp the jumper cables onto your two trailer batteries and run things from the inverter part? (like plug in the shore power cable to the inverter as mentioned earlier--converter off)
Jan-07-2014 07:26 PM
Jan-07-2014 07:19 PM
