โJan-21-2014 04:22 AM
โJan-23-2014 05:07 AM
โJan-22-2014 02:56 PM
โJan-22-2014 01:07 PM
โJan-22-2014 08:02 AM
RJsfishin wrote:
Ok, seems this really is a gell cell. So a gel cell is still a lead acid !
I wonder what their good for, except emergency standby ?
โJan-22-2014 07:54 AM
RJsfishin wrote:
Right, but OPtima sure likes to come up under gel batt search.
Is this a gel cell, or a sealed lead acid, or AGM ?
โJan-22-2014 06:40 AM
โJan-22-2014 06:12 AM
Chris Bryant wrote:This here.
Geeze- 2 minutes on the Optima website gives the faq"Optima Battery Company" wrote:
What is a gel battery? Is OPTIMAยฎ a gel battery?
A gel battery design is typically a modification of the standard lead-acid automotive or marine battery. A gelling agent is added to the electrolyte to reduce movement inside the battery case. Many gel batteries also use one-way valves in place of open vents, which help the normal internal gasses to recombine back into water in the battery, reducing gassing. Generally, gel batteries are less tolerant of high heat and are charged at lower power than traditional or AGM batteries. An OPTIMA battery is neither a gel battery nor regular flooded battery. OPTIMA is a SPIRALCELLTECHNOLOGY AGM battery.
โJan-22-2014 05:48 AM
โJan-22-2014 05:13 AM
โJan-22-2014 05:04 AM
โJan-22-2014 04:58 AM
smkettner wrote:
I don't think you will find "GEL" on the oem website.
Optima is only AGM.
Light gray case is deep cycle. Beauty of AGM is that even deep cycle has lots of cranking amps and so it will carry a start rating same as other 12v "true deep cycle" such as Trojan.
โJan-21-2014 06:52 AM
โJan-21-2014 05:48 AM
โJan-21-2014 04:56 AM
โJan-21-2014 04:52 AM
