Outlets not working in 1977 dodge sportsman "vogue"
Sneeblii
So I checked fuses and breaker box, everything looks good. I replaced outside outlet. Any other suggestions? I have never used the outlets in the month I have own the vehicle. Overall for her age she's in great shape so I wondering if there are any other simple procedures I can check myself.
7 REPLIES 7
westend
Does the GFCI reset to the operational state? If not, it may be upstream of any of the other outlets, causing other outlets not to work. Also, check for additional GFCI receptacles in the RV. They are typically located around or under sinks and water piping.
'03 F-250 4x4 CC
mkirsch
Nomad II
Nomad II
The most common cause of this issue is the rookie RV owner not understanding the difference between 12VDC and 120VAC electrical systems.
Your regular outlets will not work unless you are plugged into "shore power" which is a slang term for household electricity.
Matt_Colie
Snee,
This is not a joke.
Vibration and 40 years of getting bounced around can loosen things.
Honestly, I have had similar problems that only took finding and tightening all the connections all along the line.
And there is another problem that I have repaired for others but not had myself. Most of the AC wiring was done with solid wire romex and the vibration of the vehicle has actually caused it to fatigue and break. This usually happen very near a terminal. Sometimes under the insulation, so pull on the wires to check.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
MrWizard
Moderator
Moderator
you are plugged into shore power "120v electricity" right ?
for 120v you need one of these
#1 shore power
#2 running generator
#3 DC to 120vac inverter, uses the house batteries to make 120v for watching TV / pc etc..
then you need to recharge the house batteries
a GFI will only reset if 120v is present, aka coming to the outlet
How are you keeping your batteries charged up ?
i remember you had a question about "extra battery space"
I can explain it to you.
1997 F53 Bounder 36s
Artum_Snowbird
I am going to ask... are you plugged in to shore power?
Now this is just a guess, but fridges and furnaces back in 1977 did not need power to keep running. There really was just a few lights that ran off the battery.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
Sneeblii
magicbus wrote:
Maybe you could check to see if there is a GFI outlet installed somewhere that popped and needs to be reset?
Dave
Sorry I forgot to mention I tried resetting with no success
magicbus
Dave
Current: 2018 Winnebago Era A
Previous: Selene 49 Trawler
Previous: Country Coach Allure 36
