Oven issues
rrev
I have a Magic Chef oven in my trailer and it's really gotten the best of me lately. I used to be able to light this thing with no problems but lately........ I can't get it to light to save my butt. Any thoughts of what to do? Thanks
2008 Chevrolet Silverado 2500HD CCSB
2016 Starcraft Autumn Ridge 329BHU
2007 Starcraft Homestead 282DBS (Retired)
4 REPLIES 4
goat_428
behind the knob on controller is a small metal tab that when depressing knob to light lets gas thru to the pilot light.after checking with tech was told that sometimes the tab needs tweaked or rather bent slightly to allow gas to flow.also was informed that yes it could take a few minutes to get thermocouple hot enough to allow gas to flow to burner.....
tanman32225
If your oven has a thermofil or thermocoupler it could be bad. Both are a small tube looking device that the pilot light heats to tell the oven to all gas to flow. Just a thought but you might google them to understand them. Neither the pilot or oven will light if the above device is bad.
past-MIdirector
Easies way to light a standing pilot over is to turn the thermostat up above 200. This allows a little more gas to flow to the pilot burner. Once lite turn back to pilot or temperature you plan on using. If it won't light remove and clean the pilot burner since you may have a spider that made a home.
Mortimer_Brewst
Here's a thread from a couple of months ago that might help.
If ethics are poor at the top, that behavior is copied down through the organization - Robert Noyce
2018 Chevy Silverado 3500 SRW Duramax
2019 Coachmen Chaparral 298RLS
