Pairing on board rv style battery charger with a ctek ds250?
Viseror
Hi all.
I am upgrading my sunlight electrical system and looking to retain the ability to charge my two golf cart batteries when/if I plug into shore power. My camper came with a charger converter like most traditional rvs that charges the house battery when plugged in, should I just run the wiring to the battery? Through the ctek ds250? Will charging the batteries independentlyrics of the ds250 cause problems? What can you say about https://ballisticparts.com/die-hard-battery-charger-troubleshooting/ I leave on the first quick help is appreciated
4 REPLIES 4
2oldman
Coming back is also appreciated.
time2roll
RJsfishin
two charging systems charging 1 set of batteries, not a problem
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
BFL13
Is that the smartpass or what? Not clear on what you are trying to do. Do you mean D250S?
https://www.baintech.com.au/why-wont-my-ctek-d250s-dual-charge-from-solar-panels
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
