Power converter
Jb1980
Hello,
I have just purchased my first motorhome and it is 1996 29' Coachmen leprechaun and I am having a electrical problem. Every time I plug the motorhome into the campsite power it pops the campsite breaker. I didnt notice it when I bought it but the gentalman who had the motohome before me had it pluged it in when I bought it but what I didn't see was that on the home outlat addapter had the ground prong missing. I didn't think much of it and just bought a new one but when my boy's and I went camping and I pluged the normal 30 amp plug in at the camp sight it poped the breaker and did the same thing when I pluged in the new home plug addapter. But when I used his broken addapter it would work fine. I am wondering if I have a bad power converter or just a bad ground connection in the converter because thats where the cord comes into first.
7 REPLIES 7
time2roll
Turn off ALL breakers in the RV panel and try again. Post the results.
If no trip turn the breakers on one at a time starting with the main.
If it trips with all breakers off you have a short in the cord or a short at the connection at one end or both.
BFL13
You should say "power centre" instead of "converter" so we don't get confused. The converter is in the power centre and just converts 120v to 12v.
Meanwhile you do have a ground fault somewhere in the rig, which is why he cut off the ground prong (it is not "broken" --he cut it off) instead of finding the problem and fixing it.
Meanwhile, don't stand in a puddle and put your hand on the skin of the rig. ๐Ÿ˜ž
Agree, if you are not familiar with electrical issues, get a pro to fix it. In a 1996 rig it could be anything, but the first suspect might be the shore power cord plug itself that he cut the prong off. Perhaps a new plug on that cord, that is properly connected to the three wires would fix it right there. You have to replace that plug anyway with a proper three-prong.
If not, it is a time-consuming task to find the ground fault in the rig, and time is money (100/hr?) so lots of motivation to try to find the problem yourself.
That gets you to the suggestion earlier to try one breaker at a time to narrow down which circuit is guilty. Then you can chase down what on that circuit is guilty. (But start outside with the shore power cord plug in case that was it and save a bunch of work checking inside the rig)
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
MrWizard
Moderator
Moderator
the power converter supplies 13+v to charge the house batteries and power 12v items, are your batteries charging, did everything work on the camping trip, what about the fridge, did you use propane or put it on automatic and use electric
you have a short to ground in the wiring
this could be one of several things
frayed wiring in the 30amp shore plug
a shorted 120v heating element in the fridge
a screw thru some wiring somewhere
for testing you need to turn off ALL the circuit breakers in the breaker box of the rv
plug into shore power
did shore breaker trip ? yes/no . if yes, take your cord apart check both the male plug and the connections at the RV
if NO proceed
turn on main breaker in RV panel, only the main
shore trip yes/no
if no
turn on..only one breaker at a time
you are looking for the circuit with the problem ?
I can explain it to you.
1997 F53 Bounder 36s
1492
Moderator
Moderator
donn0128
First NEVER ever plug into a pedistal with the breakers on.
Find your electeical panel and turn everything off, including the converter. Plug in, start turning things on one at a time until the breaker trips. There is your problem. It is quite likely that your drawing too much power because the WH and refer are trying to start up.
2oldman
The mods must be taking a break from moving these posts.
Mandalay_Parr
You have an electrical problem somewhere.
Strongly suggest a qualified electrical person to help you.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
