โJun-07-2020 06:53 PM
โJun-08-2020 08:35 AM
wa8yxm wrote:
You say it blows a 30 amp fuse. Is there a 2nd 30 amp fuse (Check it) if yoru converter is bigger than 30 amps it may have two or 3 fuses in parallel ALL of them need to be repalced at the same time..
Also a shorted cell in one of those batteries can pop-a-fuse rather fast.
โJun-08-2020 05:52 AM
revcononthehill wrote:
Thank you for the excellent explanation.
So it sounds like I need to put the rest of the positives onto the one battery on the right and all the negatives on the battery to the left and use the jumper cables to jump them together. Iโll test the white one tomorrow to see what it is.
I put the batteries in the same way but am going to take them out so they arenโt reversed like that. Not sure why I did it like that again.
โJun-08-2020 04:12 AM
โJun-08-2020 04:09 AM
BFL13 wrote:
Red (pos) and white (neg) load wires to the same post?
โJun-08-2020 03:33 AM
โJun-07-2020 09:46 PM
โJun-07-2020 08:32 PM
โJun-07-2020 08:00 PM
โJun-07-2020 07:59 PM
โJun-07-2020 07:54 PM
โJun-07-2020 07:50 PM
โJun-07-2020 07:27 PM
โJun-07-2020 07:17 PM
โJun-07-2020 06:57 PM
โJun-07-2020 06:54 PM
