โNov-08-2018 04:47 PM
โDec-04-2018 05:38 PM
โDec-04-2018 03:47 PM
bkf wrote:
Another update from me. Probably the last one for now, but I've finally "fixed" the issue.
I noticed the Magnum only acted up when the temperatures got down below freezing. I put a 100w bulb inside the compartment with the Magnum, and it hasn't acted up since.
Soโฆ no idea why, but my Magnum doesn't like freezing temperatures. Looks like I'll have an extension cord running to that bay until spring ๐
โDec-04-2018 02:03 PM
โNov-22-2018 11:51 AM
dougrainer wrote:
That is a very good wiring diagram. To clarify for you. There are 2 (two) 50 amp breakers in your RV and your diagram shows those. You stated 1 previously and that made me think someone had southern engineered your RV wiring.
dougrainer wrote:
You diagram shows exactly how a Inverter/Charger When on Shore Power, the 120 just goes THRU the Inverter and back to your panel. Since it appears to happen when it gets colder, that points to a LOOSE 120 wiring connection, probably at the Inverter/Charger 120 input and output wiring. Magnums use a screw type system and not wire nuts for the 120 romex wiring. I would check those with a screwdriver. Doug
โNov-21-2018 05:41 PM
โNov-21-2018 06:38 AM
โNov-21-2018 04:24 AM
โNov-20-2018 06:58 PM
shore power-->50 amp distribution panel-->30 amp breaker-->magnum-->RV outlets?
Shore power at home, or in a campground?
The next inline diagnostic is not difficult to do work wise but may be a hassle logistics wise.
An alternate source of power.
Assuming it is as you said Power TO the Magnum. not from it. The suspect list:
โฆ
After that the inverter itself becomes suspect.
โNov-20-2018 09:19 AM
โNov-20-2018 08:09 AM
โNov-20-2018 06:04 AM
โNov-20-2018 05:20 AM
โNov-19-2018 02:36 PM
donn0128 wrote:
CHECK YOUR INCOMING VOLTAGE
Yes, I am screaming. What your saying sounds like classic high incoming votage.
โNov-08-2018 10:52 PM
