May-16-2019 09:50 PM
May-18-2019 12:53 PM
road-runner wrote:
When a double pole double throw switch is used to reverse polarity, the outside terminals are jumpered diagonally. Power is fed to the jumpered diagonals, then the center terminals to the motor.
May-18-2019 07:53 AM
May-18-2019 07:49 AM
May-18-2019 05:27 AM
May-17-2019 09:27 PM
May-17-2019 09:02 PM
road-runner wrote:
With 6 wires on the switch, I concur that it's "probably" a polarity reversing switch with no controller. If that's the case, the 2 center wires would run directly to the motor. My previous RV had a Lippert slideout that worked that way. There's one statement in the documentation that says if the switch is held after the room is fully extended or retracted, "the control" will shut off the motor after a few seconds. There's no controller in that system, so there's either something in the motor, or they're relying on the required 30 amp auto reset circuit breaker for that. One troubleshooting step says to hook a battery directly to the motor and see if it runs. Maybe that's feasible, maybe it's not. A different troubleshooting step says to hook a voltmeter at the motor and see if it shows power when the switch is pressed, and if it does, replace the motor. (If the meter does show good voltage, I'd personally verify with a direct-connected battery before buying a new motor).
May-17-2019 05:08 PM
May-17-2019 12:06 PM
road-runner wrote:
I'm posting info about my power gear slideout system. It's just FYI as yours might work the same way, or maybe not. There's an indirect torque limiting system via a controller that senses current. The controller is p/n 140-1163 and a picture can be found here https://www.amazon.com/Power-Gear-Slideout-controller-140-1163/dp/B01IF99SCI. It has a 25 amp slow blow fuse in it. The only way I know about it is from extensive snooping in every nook and compartment in the RV. Do you have a center-off in-out switch? Does it have 3 wires going to it? Are the wires going to the motor larger (or at least different) than those from the switch? If this is all true, you may very well have this controller hiding someplace. It has 6 connections: power and ground, 2 wires from the switch, and 2 wires to the motor. On the controller I have, there are no adjustments.
May-17-2019 08:58 AM
May-17-2019 07:23 AM
newman fulltimer wrote:
Find the motherboard clean the contacts check the ground if that doesn't fix the issue probable cause is a bad board
May-17-2019 02:20 AM
May-16-2019 10:23 PM
May-16-2019 10:08 PM
