May-22-2014 09:29 AM
May-23-2014 12:37 PM
May-23-2014 09:48 AM
May-23-2014 09:44 AM
NinerBikes wrote:Gjac wrote:pianotuna wrote:This and BFL13's make the most sense to me. My current routine is a week at one place at most. No need for generator, but out of water and need to dump and fill anyways. Need to wash clothes and bed sheets so go to a campground with washer, dryer and electric to charge batteries with 40 amp B&D charger over night. Can't think of a practical way to get around laundry and water after a week. How do you guys get around this(that your wife agrees to)?
Hi Gjac,
Longevity of the battery bank. (provided the solar is properly sized).
In my case, wife was optional, I decided to forgo that option.
May-23-2014 09:30 AM
Hi Gjac,
May-23-2014 09:01 AM
Hi Gjac,
May-22-2014 10:56 PM
Gjac wrote:
I have 60 gals of FW and It lasts about a week if there is no other water sources around. After a week my 2 Sam's Club batteries will be around 50 % SOC. I don't need the genset to recharge the batteries for the week. I was just wondering how many days in a row do you dry camp before you decided you needed solar power? From some replies it sounds like some decided because needing/wanting 120v conveniences like TV,etc.
May-22-2014 09:18 PM
May-22-2014 09:11 PM
May-22-2014 09:09 PM
Gjac wrote:Same as justifying owning a motorhome. 🙂
How do you justify solar if you only camp 3-4 days max?
May-22-2014 08:59 PM
Gjac wrote:In one location about a week max. Yes we use lights (LED), tv, microwave (inverter), furnace etc as we like. The battery will about go indefinitely. Although we have camped in the trees where we get maybe 2 hours of sun so the extra power helps.smkettner wrote:I have 60 gals of FW and It lasts about a week if there is no other water sources around. After a week my 2 Sam's Club batteries will be around 50 % SOC. I don't need the genset to recharge the batteries for the week. I was just wondering how many days in a row do you dry camp before you decided you needed solar power? From some replies it sounds like some decided because needing/wanting 120v conveniences like TV,etc.Gjac wrote:I would focus on the water supply and conservation first. The three of us can go a week with our 50 gal on board supply.
90% of the camping I do is dry camping but I always run out of water before I run out of battery power.
For me the excess solar gives DW comfort that we don't have to plug in so much.
So it is different for everyone.
May-22-2014 08:26 PM
May-22-2014 07:16 PM
Captain Obvious wrote:
I just picked up a 160W portable panel. This allows me to park in the shade and move the panels into a sunnier spot away from the trailer.
Wife and I love that there is no loud stinky generator. I would recommend this mod to everyone.
Thought process:
Wanted power, but didn't want to deal with generator issues.
Too afraid to put holes in roof of trailer to mount solar panels.
Found inexpensive portable system, bought it!
I got mine from Solarblvd, but they appear to be out of stock right now. Now I don't worry about power while camping, its on to worrying about the water.
May-22-2014 07:12 PM
RoyB wrote:
BFL13-WESTEND I'm hoping for similar results with my two 120WATTs Panels on the front and had planned for a 120WATT on the rear of my OFF-ROAD POPUP roof. I might be able to go with a 240WATT panel on the rear.
Can't wait until I start running some trips after all is setup...
I know what to expect with the batteries by them self so any improvement with SOLAR will be icing on the cake...
Roy Ken
May-22-2014 07:02 PM
BFL13 wrote:The battery charging aspect after 2 weeks makes a lot of sense. So 2 weeks seems like the days required that I was looking for. Also if you have an AC refer as westend.
We started off trying to do say two weeks off grid by doing the "50-90" method if cycling the batteries where about every two days we ran the gen for two hours and charged the batts back up to 90 from 50.
By week 2, it happened that the battery capacity had become less and less each time we did a 50-90, so that by the end, we just had to find shore power to get the batts back to 100% and reconditioned, desulphated, shampooed, etc.
"Some solar" fixed that, so now we can go forever off grid. It seems the batts don't get so sulphated when doing say 85-97s on solar as when doing 50-90s. Apparently the secret is to get closer to 100 (97 vs 90) on each recharge. Not perfect but you can make up the diff every so often by going to 100% using the solar where you let batt voltage climb into the 15s voltage range.
If you are only going out for a week at a time you don't need solar at all. You do 50-90s and then go home and nurse the batts back to full capacity in slow time on shore power.
For camping in the woods in winter here, solar is a waste of space. Little daylight time each day, under trees anyway, so you still need the gen to do your 50-90s except now it is so cold the furnace is eating a lot of battery and solar would have no hope of keeping up.
So it turns out we have portable solar for the nice half of the year and where we camp on the open we get lots of sun and we can do it mostly on solar with a few generator sessions if the weather goes bad for a few days. No more having to go home because the batteries have lost so much capacity from successive 50-90s.
Another benefit of solar, when camping activities are slow at times, and if you are easily amused, is that solar is constantly changing how much you are getting and you can get sort of involved in how it is going like a cheerleader or groupie. 🙂
May-22-2014 06:55 PM
mena661 wrote:How do you justify solar if you only camp 3-4 days max?the bear II wrote:Holy crap! Really? Everyday? You are a PRIME candidate for solar my friend! DW and I only camp 3-4 days max when boondocking and we're going to get a solar setup too. Surely you've already paid for it in fuel costs by now. Since you're in SoCal, you can take advantage of the cheap prices that Solarblvd in Norco offers.
During the day, I will start the generator about 10am and let it run until it runs out of gas, about 9 hours
