Sep-10-2014 05:26 PM
Sep-15-2014 02:10 PM
bigfootford wrote:
If your battery minder does not go into boost mode every day or so I would not use it for storage.
Jim
Sep-15-2014 09:05 AM
kincade wrote:
Ok, after running the trailer on my Kill A Watt for 2 days, here are the draws I see:
Wattage fluctuates between 16.5 and 17.9W
.29 A
.47 PF
34.7 V/A
at. $.11/KW, it's costing me about 16.38/yr to maintain the batteries. Not a huge expense, but it might be worth using the battery minder during the winter to cut down on electrical usage.
When I put a larger appliance on, the PF goes up to .99 (fridge, etc).
Thanks for all the advice in this thread, I sincerely appreciate it!
Sep-15-2014 08:08 AM
Sep-12-2014 10:01 PM
Sep-12-2014 11:53 AM
Sep-12-2014 11:49 AM
kincade wrote:
Thanks again for all of the great information - it sounds like this has sparked a great conversation. I'll put my kill a watt on mine this weekend and report back on the consumption (which I probably should have done first).
Bigfoot - doesn't a 20 watt continuous pull sound high for a converter that shouldn't be working or charging?
Sep-12-2014 11:19 AM
Salvo wrote:
I'm trying to understand your measurement: 0.3amps/20 W.
Are both measurements from the Kill-A-Watt?
0.3A * 120V = 36W; not 20W.
Is the difference in wattage due to the power factor? Is the power factor 20W/36W = 0.55 (at no load)?
What does the electric company charge you; 20W or 36W rate?bigfootford wrote:
Only thing running is my CO and LP sensors...
.3 amps/20watts...=480watts a day. So every 2 days or so a Kw is used.
Sep-12-2014 10:25 AM
Sep-12-2014 10:15 AM
Sep-12-2014 10:02 AM
Sep-12-2014 09:19 AM
Sep-12-2014 07:45 AM
Sep-12-2014 07:30 AM
MEXICOWANDERER wrote:
As a simplified example I have an 8 lb transformer that is used as a 6-volt power supply for a carbon rod soldering station.
I plug in the transformer and note a 9 watt load even though the transformer is just sitting there grinning at me.
After an hour or so, the lamination's (the heavy square mass of steel wafers) has grown uncomfortably warm. I wouldn't want to have to fondle the transformer for very long.
This is yet another reason why I like those switching power supplies. They are far more efficient than a transformer type AC/DC circuit.
But to bring up another point, how angry does the converter get when the whip is put to it? Excessive heat is death to electronics. Whenever I tinker I read electronic component data sheets and wince. A 100 amp gizmo may be de-rated to 10 amperes max at higher temps.
My hearing has gone the way of crank handle starting, so fan noise is not a big issue with me. My gizmo projects usually whistle with F5 on the saffer simpson scale wind velocity. Absurdly huge heat sinks. I am a true cheapskate.
Sep-12-2014 07:11 AM
