Proximity of gas can to van exhaust?
Naio
Should I be concerned about this? It seems like I should, but I have not seen anyone mention it. Maybe because it is obvious? How close is too close? What about genny exhaust?
Talking about a plastic gas can with gasoline in it, here, and driving down the road with it on the bumper.
Am I right in thinking propane canisters are not a concern?
3/4 timing in a DIY van conversion. Backroads, mountains, boondocking, sometimes big cities for a change of pace.
29 REPLIES 29
Naio
Vulcan Rider wrote:
Naio wrote:
Ok. I thought there was stuff to prevent me doing that.
There might be baffles or coils in your main filler neck designed to discourage siphoning but if your hose is skinny enough and you have a little patience getting it in there, it should work.
Certainly worth a try since you already have a pump.
Ok. I appreciate you clarifying this.
Vulcan_Rider
Naio
Vulcan Rider wrote:
JiminDenver wrote:
I wasn't suggesting running the generator off of the tank, just making it so a small amount could be pulled out and put into the generators tank.
So I will repeat this, since I think it is the only safe and sane way to do it:
Get a small gasoline safe transfer pump, either electric or manual.
Put the supply hose down into the main tank. Put the output hose into the genny tank. Pump.
I actually do have a 12v pump that says it is ok for gas. I had planned to use it from gas can to genny, but I like your method better! Will try it out.
FYI all, my van is newer but I can avoid pumping gas into genny tank while van engine is running. That sounds scary anyway.
I appreciate y'all's patience with this gas engine newbie.
Vulcan_Rider
JiminDenver
2011 GulfStream Amerilite 25BH
2003 Ford Expedition with 435w tilting portable/ TS-MPPT-45
750w solar , TS-MPPT-60 on the trailer
675 Ah bank, Trip-lite 1250fc inverter
Sportsman 2200w inverter generator
subcamper
If your van is a pre-OBDII emissions vehicle, then you should be OK.
I think OBDII started in 1996.
If your van is OBDII compliant, then any attempts to tap off the gas tank will probably set a "slow evap system leak" code or even a "large evap system code".
These systems basically pressurize the fuel tank slightly and then measure the pressure continually to see if any leaks are occurring. A tap-off somewhere in the system (gas tank or filler neck) will bleed off pressure and set the code.
It might be possible to put a shutoff valve in the tap-off so that you can turn it off when the engine is running. Of course, this means not running the generator while the van engine is running.
Steve
Naio
Ok, so can we get back to: What is a good way to implement Denver's suggestion that I run the genny of the van's gas tank?
MEXICOWANDERER
CALIFORNIA AIR RESOURCES BOARD
Now, exactly how STOOPID is the C.A.R.B.?
The following is FACT not fiction...
For years the C.A.R.B. lobbied the California legislature and spent millions of dollars of taxpayer's dollars...
Trying to ban Barbecue Lighter Fluid as being a significant contributor to SMOG. They lobbied and devoted tens of thousands of public paid employee man hours, and hired scientists who don't wear socks to lobby Sacramento for this ban.
Nuff Said
Tom_M1
dave17352 wrote:
jfkmk wrote:
Tom_M wrote:
I bought the can that I carry gas in here: Atlantic British Jerry can
The can is made in England and built to NATO specs. It is not galvanized but is fully painted inside and out. It does not meet U.S. CARB specs so for legal purposes Atlantic British sells it stating that it can not be used for gasoline.
It is about the best can for transporting gasoline. It simply does not leak.
Why would you transport fuel in a container that federal law prohibits its use for transporting fuel??
Curious what is wrong with this can. What are the "CARB" specs.
The NATO spec Jerry can is the only can that I have found that will not leak. The lid has a cam lever action that is quick to open and close. This can was developed by the Germans back in the late '30s and has been used in Europe since.
Wikipedia Jerrycan link
Quote from Wikipedia:
"The California Air Resources Board, also known as CARB or ARB, is the "clean air agency" in the government of California."
Wikipedia CARB link
What's wrong with today's cas cans?:
http://www.today.com/video/today/53733179
http://www.gad.net/Blog/2012/11/22/one-mans-quest-for-gas-cans-that-dont-suck/
http://www.otherpower.com/gas_cans
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
NinerBikes
Not quite sure, I live here, but I am willing to bet they are ridiculous, probably something to do with controlling a small amount of hydrocarbon vapors while refueling is my guess. All portable gas cans here are now unvented.
dave17352
NOW 2017 Leprechaun 260ds
2005 Forrest River Cardinal 29rkle FW
1998 Lance 980 11'3" TC
2017 CHEVY 3500 SRW 6.0
B@W turnover ball @ companion Hitch
Honda eu3000 generator mounted on cargo rack
Crestliner 1850 Fish Ski boat mostly fishing now!
Naio
JiminDenver wrote:
What about making it so you could draw off a small mount of gas from the main tank? That way you wouldn't have to have a full can to store or a very limited reserve. Phil says the 650 sips the gas so you wouldn't have to pull much at a time.
I like this idea a lot, also because I have trouble lifting and my genny use will likely be VERY variable -- i.e. not at all for months a t a time and then sometimes daily.
Suggestions on how to do it? I have a vague idea that modern cars have antisiphon barriers.
MEXICOWANDERER wrote:
Gasoline expands like CRAZY. Do not fill jug more than 80%
With a CLEAN jug, wrap a SPACE BLANKET around it, then a couple of bungee cords. They need to fit TIGHT.
Thank you. Never know when I might need this suggestion.
How is your heart doing?
jfkmk
Tom_M1
Tom
2005 Born Free 24RB
Minneapolis, MN
