Jul-22-2015 11:11 PM
Aug-08-2015 06:44 PM
doughere wrote:
If you ground it at both 14 and 15, the 4 batteries at the 15 end will wind up carrying more of the load. Grounded at 14 only will give a better balance.
Doug
Jul-26-2015 06:49 PM
Jul-26-2015 05:55 PM
doughere wrote:
- 14
+ 13
Jul-26-2015 04:23 PM
Jul-24-2015 08:47 AM
Jul-24-2015 12:20 AM
pianotuna wrote:
Hi,
If you want the system to have perfect balance then each 'set' of six volts needs to have cables to a buss bar, and all cables should be the same length. This is method #3 from the Smartgauge web site.
It shows four jars--but you can leave out one, I'm certain.
Jul-23-2015 05:04 PM
Jul-23-2015 01:09 PM
Racorman wrote:Now this will make a huge difference. 600w might be enough but the extra panel does not add much cost and will come in handy in marginal conditions.
I'm planning on installing (3) 300 watt solar panels that will fit well on my roof. Because these will be 900 watts of high voltage panels I'm going to install an OUTBACK FM-80 controller.
Jul-23-2015 08:18 AM
smkettner wrote:
Again I would skip the 15 ground connection.
Still not 'perfect' but close as you will get without a major effort.
Now lets talk about how you are charging those batteries to help with the needed capacity.
Jul-23-2015 07:34 AM
Jul-23-2015 07:08 AM
wa8yxm wrote:
Looks good to me. I keep hearing about that "More load" stuff.. Yup, True, but how much different is it. 1% 0.1%, 0.001% I doubt it will hit more than 1% so do not worry about it (And that only if you have like 5,000 watts of inverter sucking power).
Jul-23-2015 07:00 AM
Jul-23-2015 05:56 AM
Jul-23-2015 05:38 AM
