noticed i was leaking fluid underneath the front of the truck onthe drivers side....by weeks end the truck made a straining sound when turning right or left. After taking it to the mechanic...knowing i needed the truck for the weekend he did a quick inspection and stated he believes he corrected what he thought was wrong...
two weeks later same problem? after getting the truck on the lift..states the rack pinion steering is cracked and needs to be replaced? sound correct?
Moved to Tech Issues forum from Towing.
Sir Buffalo!
2006 Zinger by Crossroads 27BHS
2010 Toyota Tundra Crew Max 5.7
