Re-igniter - where does yellow wire go?
GaryS1953
Hello All - in trying to diagnose / fix Dometic RM2652 propane operation issues I accidentally pulled the yellow wire off the re-igniter. There were only 3 wires total, and the only one disconnected was the yellow. Does anyone know if it goes on the positive, or negative terminal? Thanks
Gary in Michigan
2014 Chevy Silverado 1500 Double Cab 5.3 Liter V8
1996 Coachmen Catalina RB210 21' Fifth Wheel
495 Watts Solar, 40 AMP Renogy Tracer MPPT Controller,2 GC2 6V Batts.
7 REPLIES 7
GaryS1953
Wow, thanks Guys. I guess I just don't speak "wiring diagram", but it makes sense to go to the positive terminal.
Gary in Michigan
Chris_Bryant
fat fingers ๐Ÿ™‚
-- Chris Bryant
Chris_Bryant
Should go to + other end should be gas valve and main circuit board. Nothing is connected to the L terminal.
-- Chris Bryant
wnjj
Joe417 wrote:
On page 14, upper right corner, it shows the yellow wire on the "+" terminal. It applies power to the re-igniter board when the gas solenoid is energized.
I agree. I also found pictures of modules like that with the yellow wire in the 3rd position (+).
Joe417
Joe and Evelyn
GaryS1953
Hmm, I can't make sense of it, but you are saying it's correct I my picture?
Gary in Michigan
BFL13
Scroll down to p17/34, seems to have it going from N at top right?
http://www.fourwh.com/NewDometicRefrigeratorManual.pdf
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
