Renogy 20/40 amp DC to DC battery charger (UPDATE)
grizzzman
I set this unit up as a super jumper? I had an old set of 4 AWG 20-foot real copper leads. I installed new parrot beak clamps and cut them at a 6' mark. I installed the charger. I used a fuse as the on/off switch. I hooked it up to a sulfated battery (voltage was 12.34 and had been set in the garage for 6 months) The "smart" charger went from 14.7 to 13.8 (float) in less than five minutes. So much for the "smart" charger eh? Then I hooked it up to one that was charged a few months ago. (Its voltage was 12.50) and it worked as it should. The nice thing is it has Lithium settings. You can set a single voltage from 12.6 to 14.6 (see the manual) It can also be used as a power supply. The unit has dual cooling fans (bad if you are in dusty conditions as I am while camping) So keep that in mind. It is now in a pelican case under the dinette. Oh, there is an error in the manual about setting up some of the Li settings. they are working on correcting. For the price at least for me was worth it.
2019 Ford F150 EcoBoost SuperCrew
2016 Rockwood Mini Lite 2504S. TM2030 SC2030
640 Watts Solar. Costco CG2 208 AH and Lifepo4 3P4S 150 AH Hybrid. ElectroDacus. Renolagy DC to DC charger. 2000 Watt Inverter.
Boondocking is my Deal
4 REPLIES 4
NRALIFR
Thatโ€™s a heck of a good price for its capacity. I wish those had been available when I was looking for a DC-DC charger. I ended up buying a Redarc 25 amp for about $375. A 40 amp was about $450.
I do like it though. Mines installed permanently in the TC, and Iโ€™m able to run the fridge in DC mode while driving now, and still arrive at camp with a fully charged camper battery. One nice byproduct of the DC-DC charger is the DC mode on the fridge now works better because the voltage to the heating element is maintained at a higher level.
2001 Lance 1121 on a 2016 F450 โ€˜Scuse me while I whinge.
And for all you Scooby-Doo and Yosemite Sam typesโ€ฆโ€ฆโ€ฆ..Letโ€™s Go Brandon!!!
BFL13
https://www.renogy.com/renogy-12v-dc-to-dc-on-board-battery-charger/
Wait till it all loads and see the specs etc.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
grizzzman
pianotuna wrote:
So output voltage can be made higher than the input voltage? 20/40 means?
yes, 14.00 in 14.7 out during my test. 50 amps at the truck 40 amps output. they have a 20 amp and a 40 amp unit with plans for a 60 amp version.
pianotuna
Nomad II
Nomad II
Regards, Don
