Replacing swollen wood on slide out bottom (outside)
jayspi
Disclaimer: I'm a complete newb. This is my first RV. I have an issue that I want to try repairing myself, though. Here goes...
Note: The pics are here. The problem I'm concerned with are the ones on the outside bottom of the RV. I already had the dealer dry out and patch the wood on the inside corners (it wasn't rotted, just wet).
I recently bought a used 5th wheel and found that there is debris coming in one of the corners when I bring in and then retract the slide out (see attached pics). From what I can tell, the original problem was caused by water that was coming in the corner of the slide out. I had the dealership re-caulk that and dry the unit out. However, the problem now is that the undercoating in that corner got swollen from the water. Now, when it rains (and I live in the Pacific Northwest so at this time of year it's constantly raining) water runs down the side of the slideout and then runs underneath the underbelly, which is continually making the problem worse.
Now, I *could* take it back to the dealer but they did a pretty half-@#@ job the first time around. I know they won't repair it well since it's a used unit. So I want to fix it myself.
First step is to install a slide out cover, which I'll be doing this week.
Second step is to put some sort of lip on the bottom of that side of the slide out to keep condensation from running under it in the future (I found some good Youtube tutorials on that).
The THIRD step, and the one I have questions about, is how to patch the bottom of the slide out so that it doesn't keep dragging debris in with it.
I contacted the dealership and this is what they suggested: "A suggestion would be to get whatโ€™s called belly rap tape that comes in 4 inch width. You can use that to cover the area where the corners are or even go the whole length of the underbelly of the slide just to make sure.. The area would need to be dry in order to do this and the wood sprayed with undercoating. "
So that raises two questions for me. First, what does he mean by "spray the wood with undercoating"? I did some research and can't find anything that relates to that.
Second, after I've put on said undercoating, what type of belly wrap tape do you guys recommend? Searching around on Amazon leads me to the "Flex Mend Underbelly Repair Tapee", but I have no idea if that's what I need or not. It seems to be more for repairing the underbelly of a unit, not for patching wood.
Thanks in advance for any tips!
2004 33RL Colorado 5th wheel
2013 Ram SLT Cummins dually
Full-timing since February 2015!
18 REPLIES 18
puttd
I'd say that if you are in the position to make the dealer take it back, do that. If you are in the position to make them actually fix it, do that.
jayspi
geotex1 wrote:
jayspi, how good of a DIYer are you? I'd personally pull the slide box out of the camper (not as scary as it sounds) and replace the bottom where I could work easily to keep everything square and true. I'd use marine-grade plywood as well and do some flashing work with aluminum to keep water out. Your dealer is talking about the same material used for spray-in pickup bedliners. They are using it now in lieu of the fabric and tape, especially on slide-out boxes. I would definitely have this done if taking the box out or repairing in-place. You just need to find an applicator that can do it (not all the pickup sprayers are certified to also install in other applications - see Rhino and Line-X websites).
Well, to be frank, I'm not that good of a DIYer. I plan to learn, but I'm trying to keep it to projects that I'm confident I can finish.
What the dealer did on the INSIDE is dry out the wood completely and then lay fresh wood down on top of it. Not exactly a stellar repair, but the wood on the inside isn't rotted so it works for now. It's something I can circle back to in the future, but right now our main focus is getting it livable.
From what I can tell the slide out is perfectly sturdy, it's just a matter of it dragging in debris. The wood isn't rotted or soft to the touch when it's dry. Is there anything I can do to just patch it for now without having to pull it out? We have about 3 days of sunny weather this week so it's dry right now. After that I can't count on it getting completely dry again until May / June. Even with it covered it will be constant rainy & misty weather that will keep it chronically damp until summer. It's hard to predict when it will be sunny in Seattle again ๐Ÿ™‚
In a worst case scenario, if there's not an easy patching job that I can do, will it cause any permanent damage to the slide if we continue to use it? If that's the case then I'll take it back to the dealer and insist they fix it.
Thanks again...
geotex1
Huntindog
Good thing you aren't having the dealer do the job.
I have no idea what they are talking about.
It almost sounds like they made it up.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountry CC DA 4X4 DRW
