โFeb-06-2016 04:39 PM
โFeb-21-2016 09:11 AM
โFeb-08-2016 07:44 AM
JRRNeiklot wrote:No need to cut holes just run the positive wire in wire loom underneath and use a frame ground for the slide. Or if you like use a piece of plastic electrical conduit for the wire and any future wires.
I would have to run those wires the length of the trailer to the new battery bank, and I really don't want to start cutting holes in the trailer to run the wires. I was hoping there was an easier way to tie into the system.
โFeb-08-2016 07:12 AM
JRRNeiklot wrote:OK, where did the slide connect?
I have a hot and a ground to the battery only.
โFeb-07-2016 11:34 PM
CA Traveler wrote:
My 04 Endeavor slide power was connected directly to the battery and yours may be also. Use a wire tracer starting at the slide motor and find out how the wiring is routed.
โFeb-07-2016 06:43 PM
Chris Bryant wrote:
Unless you have disconnected the original wiring, you should be able to simply bolt the hots together and grounds together ( hot to hot and ground to ground, obviously) power will feed from the load center through the original lines to the slide wires. Both should already be protected by fuses or circuit breakers.
Otherwise , follow the wires and find where to tap in,.
โFeb-07-2016 06:40 PM
2oldman wrote:JRRNeiklot wrote:How are you charging these two banks?
I would have to run those wires the length of the trailer to the new battery bank, and I really don't want to start cutting holes in the trailer to run the wires..
โFeb-07-2016 07:38 AM
โFeb-07-2016 06:53 AM
โFeb-07-2016 02:29 AM
โFeb-06-2016 08:50 PM
smkettner wrote:
There is still a main battery cable to the old battery spot right?
That should easily power the slide. Just connect them with a 40 or 50 amp fuse.
โFeb-06-2016 06:53 PM
โFeb-06-2016 06:26 PM
2oldman wrote:
Why isn't this a simple matter of taking the wires from the tongue battery,?
โFeb-06-2016 05:56 PM
โFeb-06-2016 05:37 PM
