the one for my Sahara DP is just a little thing under the dash
it doesn't take much vacuum to move heat&A/C air duct flappers
IF that is all yours does the Ford part should work find
they all connect to a reservoir, so they don't run all the time
check for vacuum leaks, there is a reason that pump burned out
I can explain it to you.
1997 F53 Bounder 36s
