Ryobi 2300 generator keeps overloading
jonaz
I have a 2021 Coachman Catalina.
I bought Ryobi 2300 Inverter generator. My intent is to run small stuff, like the LCD TV, lights and my work laptops.
When I plugged the generator into my 30amp trailer connection, it overloaded the generator. The AC was not on.
Why is my trailer drawing so much load? I had to turn off the GFI in the breaker panel box because it was causing an overload.
I can get the fireplace heater to run but not the TV.
Any suggestions?
Thank you in advance!
2007 Dodge Ram 1500 4x4 5.7 Hemi (3.92 gears)
Prodigy brake controller,Weight Distribution Hitch
2021 Coachman Catalina 263BHSCK
33 REPLIES 33
Grit_dog
Navigator
Navigator
But it doesnโ€™t blow a breaker on a different genny or shore power?
If it does then itโ€™s a live short in the camper.
If it doesnโ€™t, itโ€™s the generator.
Does the genny overload with a different load than the camper? Presumably not.
Not sure what you mean turn offf the gfi in the panel.
jodeb720
start by flipping the breakers in the box -
Make sure your Fridge is running on gas not Auto (that's pulls a few amps)
Make sure your water heater is running on Gas - not electric.
One at a time, flip your breakers on and see if that resolves your issue.
Eventually you'll find the circuit that's utilizing all your amps and you'll be able to charge your batteries as well as run your tv, etc.
jonaz
Yes, I think you are right. Any suggestions? Again, all I want to do is run the lights, TV and maybe the fireplace.
Flute_Man
Your converter will draw a lot at the beginning because itโ€™s trying to charge your batteries. The TV may be on an inverter circuit that you have shut off.
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
