โJun-17-2021 11:12 PM
โJun-20-2021 05:10 PM
wolfe10 wrote:
Actually, by far the BEST location for the muffin fans is at the top of the condenser blowing out the roof/upper vent. Much more linear flow/less turbulence over the condenser.
Also insure that your refrigerator manufacturer's installation clearances ARE correct. Many have a space above the refrigerator which leads to both turbulence and the retention of heat.
Same for verifying clearance from back of refrigerator to outside wall. Too much is NOT good. It is all in your refrigerator installation manual.
โJun-20-2021 04:25 PM
โJun-20-2021 04:22 PM
โJun-20-2021 04:15 PM
โJun-20-2021 03:30 PM
โJun-20-2021 12:35 PM
wolfe10 wrote:Have you come across centrally located fridges? The lower vent is through the trailer floor.
โJun-20-2021 12:09 PM
lostbytes wrote:
To add to the above statements. If you use a fan in the back. Make sure propane RUNNING FLAME or pilot flame will not be interfered with. Those computer type fans should be ok but more powerful ones? I used to have my flame door opened on my other RVs. Now I don't.
โJun-20-2021 11:32 AM
โJun-20-2021 10:37 AM
wolfe10 wrote:wopachop wrote:
Not the safest approach but if youre living inside the unit with your AC running figure out a way to let the cold interior air enter the back section of the fridge. Ive been doing that for awhile. Most people dont really understand the concept. It works pretty good if you are already spending the money to cool the inside of your trailer and stuck with an absorption fridge. You can vent 80F degree air up the back of the fridge instead of 110F.
The most important statement is the first one: NOT THE SAFEST APPROACH.
Propane can leak when refrigerator is running on propane. It could also start leaking when it is not running from the propane connections and solenoid in the back of the refrigerator.
PLEASE don't do this, particularly if the vent is lower on the inside than the location in the back of the refrigerator, as propane is heavier than air and will happily descend into your interior.
โJun-20-2021 06:14 AM
โJun-19-2021 09:35 PM
groundhogy wrote:Im running 4 fans. 3 inside the fridge and 1 outside. Going on my 3rd year of mega hot full timing with an absorption fridge. I want to help you if interested. Ive tried lots of weird stuff. The old folks on here 24/7 wont comprehend these new techniques. Their intentions are good but their info is just mediocre outdated nonsense they typed over and over back in the day. Up to you to decide. All im trying to say if that if youre in AZ and its 110F outside i can help you to make your absorption fridge get below 40F.
There is a muffin fan inside the fridge, but adding another may be my next step depending on my results.
โJun-19-2021 09:05 PM
โJun-19-2021 08:17 PM
โJun-19-2021 08:06 PM
