Sensor Panel
Dale_Cindy
all of our sensor lights are out (gray, black, propane, freshwater)
check fuses, we are plugged in, mirco, frig, tv all on.
4 REPLIES 4
Dale_Cindy
We have a 38ft Motorhome, fleetwood. We have check fuses but not sure which one is the panels.
Lwiddis
First effort is always a fuse check.
drsteve
Is this a TT with a basic electrical system, or a coach with a more sophisticated control setup? If the former, it sure sounds like a fuse.
2006 Silverado 1500HD Crew Cab 2WD 6.0L 3.73 8600 GVWR
2018 Coachmen Catalina Legacy Edition 223RBS
1991 Palomino Filly PUP
midnightsadie
pull the fuses sometimes they get oxidation on them. all out sounds like a fuse.
