“Service Temporarily Unavailable”
3_tons
I occasionally get this page when navigating through this RV net forum...
“Service Temporarily Unavailable - The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Jakarta/ISAPI/isapi_redirector/1.2.40”
It sometimes tends to go away upon a refresh - Any Ideas??
22 REPLIES 22
BillyBob_Jim
Emporer Marcus Euraelius Tiberious Lemonis must have royally decreed a cutback in the IT department.
Dusty_R
When I get that message I hit the back button then do a double click.
Earl_E
I finally switched to forums.goodsamclub.com and I not only don't get those errors but the site is much, much faster. They should just deep six rv.net.
2007 Northwoods Arctic Fox 32 5S Fifth Wheel used for fulltiming for several years--SOLD
2014 Sunnybrook 26rl to poke around the smaller parks in the great Southwest
2007 Chevy Silverado 2500 HD Diesel
Prodigy brake control
DFord
RobG wrote:
Since the error is happening on multiple sites, it just means that the same server(s) are used for those sites as well.
You must have mis-read what works and what doesn't. Only RV.NET users are experiencing the "Service Unavailable" You can access all of the same information using your same login credentials using 3 other URLs. I don't think it's a server issue.
These all work and you won't see the service unavailable BS:
https://forums.trailerlife.com/
https://forums.motorhome.com/
http://forums.goodsamclub.com/
Try it here: http://forums.trailerlife.com/index.cfm/fuseaction/thread/tid/29896303/gotomsg/29898269.cfm#29898269
Don Ford
2004 Safari Trek 31SBD (F53/V10 20,500GVW)
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
BlueOx Aventa II Towbar - ReadyBrake Inertia Brake System
Dtank
DFord wrote:
There are several ways to access these forums and only RV.net seems to be experiencing the problems according to reports.
Try https://forums.trailerlife.com Your login credentials (username and password) will work just the same there and you won't see the dreaded Service Unavailable.
The above works great - not so for RV.Net.
RobG
As somebody who has done websites/programming/neworking for 20+ years, it looks like it's either a hardware or software problem (which could be one of those painfully obvious statements). What that means is if it's hardware, then they may have outgrown the current server and need to upsize it... either more RAM, more CPU, etc. If it's a software problem, it could be an issue in Windows itself (or whatever the OS is), or it could be an issue with ColdFusion, the middleware that serves the forum pages.
The way these Service Unavailable errors are appearing and disappearing almost makes me think they have it set to automatically reset itself whenever it happens... which causes a delay while the service (the webserver or ColdFusion in this case) restarts itself.
A client I recently did some work for ran a CMS on ColdFusion on an OLD 32-bit version of Windows, and it had all kinds of problems. If they're trying to do the same thing here, then it's definitely time to upgrade.
If any of the "powers that be" need help with this, they should feel free to contact me, as I can help diagnose the exact problem and recommend a solution.
BTW, even trying to make this post I'm getting the errors, so it may end up double-posting.
2019 Arctic Fox 992 Truck Camper
2006 Keystone Raptor 3814SS 5th Wheel Toyhauler (live in it fulltime)
2005 Dodge RAM 3500 Quad Cab Dually 4x4 SLT 6sp
A quad, a few motorcycles, and a dog.
DFord
It's no doubt the systems a mess right now. I'm not sure how many different ways there are of accessing it but all these work with your present login credentials:
Only using RV.net is giving the troubles.
Don Ford
Route_66_Travel
Thanks for that info. I made a duplicate post this morning because when I clicked on Submit to enter my post I got the “Service Temporarily Unavailable” so I entered it again using Safari instead of Firefox, then both posts showed up.
Joe417
I started having similar issues a week or so ago.
I go on to something else. Try to come back later. Some days/times are worse than others. Tonight I've had only one failure.
Joe and Evelyn
Johno02
Wondering if the storms here in the middle have impacted some internet servers or connections. We are in Springfield MO at a KOA. Have had good internet via campground WIFI and Verizon mobile both. After the storms yesterday, both connections are flakey, dropping in and out, and a lot of "unable to connect" messages. Have talked to others that are having the same problems today in the area. Had to go out to the store earlier today, and experienced the same problem. Of course, ISPs and Wireless providers will never admit it. Hope they get it fixed quickly.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
MEXICOWANDERER
Jeezo try it from outside the U.S. 😞
2oldman
Well, it works better than the McDonald's app.
Roger10378
It started to do this to me the last few weeks. It looks like we have outgrown the system. It is worse in the evening than in the meddle of the day.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
cavie
x2 on trailer life.
2011 Keystone Sprinter 323BHS. Retired Master Electrician. Retired Building Inspector.
All Motor Homes are RV's. All RV's are not Motor Homes.
