Shore power stopped--gen works
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
Jul-08-2018 08:29 PM
Microwave works.
Started the genny and everything works. On shore power there is a problem.
Is my transfer switch going out? I'm the dum dum who had both air conditioners running and switched from gen to shore power a couple days ago.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Jul-09-2018 11:48 PM
adapters can get hot enough to burn a wire on the inside
your A/C on a 20amp circuit, voltage goes down current goes up, resistance goes up, heat level goes up, its bad spiral that keeps going and getting worse
until something fails
heating the cooling, cycling will cause screws to loosen
as you found out
1997 F53 Bounder 36s
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Jul-09-2018 11:01 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Jul-09-2018 04:43 PM
apparently you have a 4 blade 50amp rv service ( but you never said yes or no )
it has (2) hots (1) neutral (1) ground
you have this plugged into (3) blade 30amp adapter , plugged into a 30-15 adapter ?
YES or NO ?
we all thought the 50 to 30 had burned out (1) of the hots inside the adapter
rubber dogBone 120v RV adapters, NOT parts inside the RV
you do need to answer the questions that are asked by us
if you don't understand the question, ok, tell us
but we can't help when you don't answer
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Jul-09-2018 03:12 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Jul-09-2018 02:45 PM
I'm hooked to a 20amp breaker and pulling 14amps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Jul-09-2018 04:39 AM
2006 40' Landmark Mt. Rushmore
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Jul-09-2018 02:30 AM
Using generator everything works.
Plugged into shore I have no 12v and half my 110v power is gone.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Jul-08-2018 11:33 PM
if you have a 50amp using a 30 amp adapter,
it connects (2) legs to one 30amp hot leg
adapter has burned out
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Jul-08-2018 10:30 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Jul-08-2018 10:29 PM
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Jul-08-2018 09:55 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Jul-08-2018 08:49 PM
My panel has 2 legs. Right side is dead. Bu my feed from shore power is only 1 leg.
So it's transfer switch right? On the genny I had both air condertions cranked. On shore power there is no 12v and everything on the "right side leg" is dead.
Does a transfer switch have heat sensitive temporary breakers? It's been hot. Everything worked fine this morning.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Jul-08-2018 08:42 PM
In my case, it was the negative wire off the converter that fed to the battery. I jiggled it, and all the lights in the house lit up. Tightened the screws up and it worked forever.
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Jul-08-2018 08:38 PM
then yes, there is a good chance it is the transfer switch
but start with the easy stuff
take a close look at your shore cord male plug
is burnt is it pitted and black
is it melted
goto home depot etc.. buy a new TT-30 male (trailer 3 blade male)
and replace it
your 30amp Transfer switch is most likely located behind the breaker panel/converter
which means several hours of work, no power, and the need of someone electrically handy to get in there and check it
