Shore power stopped--gen works
wopachop
Not sure what happened my converter is not working on shore power and half my 110v is dead.
Microwave works.
Started the genny and everything works. On shore power there is a problem.
Is my transfer switch going out? I'm the dum dum who had both air conditioners running and switched from gen to shore power a couple days ago.
14 REPLIES 14
MrWizard
Moderator
Moderator
just as you found the loose wire in the blue (4) wire female plug
adapters can get hot enough to burn a wire on the inside
your A/C on a 20amp circuit, voltage goes down current goes up, resistance goes up, heat level goes up, its bad spiral that keeps going and getting worse
until something fails
heating the cooling, cycling will cause screws to loosen
as you found out
I can explain it to you.
1997 F53 Bounder 36s
wopachop
Im sorry i didnt realize the adapters could fail without very easy to spot physical damage. They looked in good shape. Can the wire fall off the connector under the rubber?
MrWizard
Moderator
Moderator
glad you found it and fixed it
apparently you have a 4 blade 50amp rv service ( but you never said yes or no )
it has (2) hots (1) neutral (1) ground
you have this plugged into (3) blade 30amp adapter , plugged into a 30-15 adapter ?
YES or NO ?
we all thought the 50 to 30 had burned out (1) of the hots inside the adapter
rubber dogBone 120v RV adapters, NOT parts inside the RV
you do need to answer the questions that are asked by us
if you don't understand the question, ok, tell us
but we can't help when you don't answer
wopachop
It was a loose wire at the socket that plugs into the trailer. Doesn't appear to have been arcing.
wopachop
Adapters? Like power cord adapter or a part inside the transfer switch?
I'm hooked to a 20amp breaker and pulling 14amps.
eHoefler
Your adaptors are burned out. Sounds like you are on a 15 amp trying to supply a 50 amp.
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
wopachop
I'm on 15amp.
Using generator everything works.
Plugged into shore I have no 12v and half my 110v power is gone.
MrWizard
Moderator
Moderator
i'm confused, do you have a 50amp RV or a 30amp rv
if you have a 50amp using a 30 amp adapter,
it connects (2) legs to one 30amp hot leg
adapter has burned out
doxiemom11
Have you checked the power source you are plugged into? We have had 1 leg with no power on a power connection and the problem was not ours. We also lost 1/2 of the 110 inside when that happened.
stickdog
Have you checked that both legs are live at the pedestal. We've had a bad leg on the fifty amp breaker.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
โ€œA good traveler has no fixed plans, and is not intent on arriving.โ€ Lao Tzu
pianotuna
Nomad II
Nomad II
Replace the transfer switch with male and female plugs as necessary.
Regards, Don
wopachop
It's been a long hot day my brain is working at 10%.
My panel has 2 legs. Right side is dead. Bu my feed from shore power is only 1 leg.
So it's transfer switch right? On the genny I had both air condertions cranked. On shore power there is no 12v and everything on the "right side leg" is dead.
Does a transfer switch have heat sensitive temporary breakers? It's been hot. Everything worked fine this morning.
Artum_Snowbird
Sounds like the batteries are failing. Why are they failing? Well you have to determine whether they have lost the connection to the converter, or if the converter has failed. Put your meter on the converter output positive and negative terminals. If you see 13.6 there, you should see it on the batteries on their positive and negative too. If you don't see it on the batteries, the wires between the converter and the batteries are loose.
In my case, it was the negative wire off the converter that fed to the battery. I jiggled it, and all the lights in the house lit up. Tightened the screws up and it worked forever.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
MrWizard
Moderator
Moderator
IF everything, and i mean everything for 110v works with the generator
then yes, there is a good chance it is the transfer switch
but start with the easy stuff
take a close look at your shore cord male plug
is burnt is it pitted and black
is it melted
goto home depot etc.. buy a new TT-30 male (trailer 3 blade male)
and replace it
your 30amp Transfer switch is most likely located behind the breaker panel/converter
which means several hours of work, no power, and the need of someone electrically handy to get in there and check it
