shorted out 12 volt system
1856rmp
I contacted chasis with wrench while tightening battery terminal and sparks flew. The 12 volt system is not working now as a result.Trying to figure out how to fix. 2005 Fleetwood providence 39L. Any suggestions as to figure out what to do
16 REPLIES 16
RoyB
You may have at least three blown fuses.
One is located very close to the battery terminal and on the older trailers is an IN-LINE fuse. The newer trailer sometimes use a resetable in-line circuit breaker here.
There are two other fuses located on the 12VDC Power Distribution Panle labeled REVERSE POLARITY on my panel.
This is the location of my two reverse polarity fuses. These two 12VDC plu-in fuses are located in the center of the 12VDC fuse panel and are sitting by themself...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
2oldman
First, check battery. Second, battery wiring. Third, all fuses.
