โMar-08-2014 03:54 PM
โMar-08-2014 07:55 PM
โMar-08-2014 07:51 PM
az350x wrote:Old-Biscuit wrote:
Wife turned the wrong switch ON (gas) and it lit......BUT it went out or you had wife turn it off BUT it won't relight......Correct????
Do you have 2 switches on panel where light is?
Just one switch?
Is there another switch in outside compartment??
Which Brand WH......Suburban or Atwood??
The electric and gas are two separate heating sources......turned ON & OFF by separate switches.
Just a guess.....you have a Suburban with an ON/OFF switch in outside compartment that is ON and electric element burnt out due to WH tank being drained and RV was plugged into AC power source.
No indication of electric working, being ON except for hot water when AC power is available.
Suburban. So yes, I guess I understand now that switch inside kitchen with light next to it is gas switch. Outside, on the heater itself is a black rocker switch that I guess is just for turning element on/off.
โMar-08-2014 07:50 PM
โMar-08-2014 07:43 PM
Just one switch?
โMar-08-2014 07:35 PM
โMar-08-2014 04:22 PM
โMar-08-2014 04:05 PM
โMar-08-2014 04:02 PM
