shower taps leaking
SM49
Is water supposed to run out of the tap assembly where the shower hose goes on when you turn the taps off, old one did it & so does the replacement
3 REPLIES 3
SM49
Thank you
rockylarson
Yes.
Jan and Rocky
Volunteers for USFWS. 29 refuges with 9300 hrs ea since 2006. 2004 Allegro 30DA, Workhorse 8.1, Banks, 2012 Jeep Liberty Jet, Blue Ox Aladdin, Brake Buddy Advantage Select, 300 watts solar, 5 Optima group 31 AGM's, 2000watt Ames PSW inverter.
Dutch_12078
There's a vacuum breaker at the hose attachment point that lets the hose drain after the water is shut off at the faucet(s).
Dutch
2001 GBM Landau 34' Class A
