shutting off 12v power
tuna_fisher
Doing some wiring on my rig, can I just disconnect the battery or do I have to shut down my solar too? I can disconnect the + lead at the controller seeing as I don't have a on / off switch in line.
2001 GMC DM, 1995 Lance Lite, @005 Eclipse Toyhauler, Toy's!;)
5 REPLIES 5
tuna_fisher
wnjj wrote:
John Wayne wrote:
What not just cover the solar with cardboard or rugs.
Itโ€™s probably easier to disconnect a wire than to access the roof.
You got it!!!
wnjj
John_Wayne
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
Lwiddis
WindyNation, for example, says never attach the panels to the controller unless the controller is attached the the batteries.
BFL13
Some solar controllers can be damaged if you disconnect from the battery while they are still connected to the panel. Disconnect from the panel before you disconnect the battery (and VV after)
The converter might still be able to power the 12v without any battery connected, depending on how that is set-up in your rig.
Also you have the truck battery connected so unplug that from the camper (always live with a GM--no relay like with a Ford)
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
